Page 3 of 3 1 2 3
Re: Rock,hard place front main bearing [Re: Clanton] #2310443
05/24/17 04:45 PM
05/24/17 04:45 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
What the heck!?I have it down to the crank with pistons in and it only takes 28 ft lbs to turn it.I noticed it after removing the cam timing chain.I need to hold up here and ponder this.This does not change that the bearing is burned!!!
Re: Rock,hard place front main bearing [Re: Clanton] #2310452
05/24/17 05:04 PM
05/24/17 05:04 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
1 of the 1st things to do is put the #1 main on and see if it is tight again.I noticed something else,The TC nose has the paint off of it and I wonder if the trans is pushing on the crank making the thrust tight in turn making the engine hard to turn by hand.I will get to checking the thrust bearing and the back of it after checking the engine good.I am open for ideas on the order to check things!!!!
Re: Rock,hard place front main bearing [Re: Clanton] #2310482
05/24/17 06:03 PM
05/24/17 06:03 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am going to go ahead and check the thrust bearing being that I cant get the #1 in to check it without lifting the crank.
Re: Rock,hard place front main bearing [Re: Clanton] #2310551
05/24/17 08:05 PM
05/24/17 08:05 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Some good news is all the rods,pistonbores look good.1,2,3 main have just a littler heat in them on the block side and not over the oil hole.I will have the crank measured to start and to be honest I think the .001 under bearings will do the trick but we will see.
Thanks for listening.ttyl
ps:The thrust was .006 with a dial on it.
Re: Rock,hard place front main bearing [Re: Clanton] #2310633
05/24/17 10:25 PM
05/24/17 10:25 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
My eagle crank mains measure 2.7475 where my old crank measures 2.745.I have a summit dial bore to measure the block but I wanted to ask about the block temp when measuring should it be 65/70*F?
Re: Rock,hard place front main bearing [Re: Clanton] #2310635
05/24/17 10:32 PM
05/24/17 10:32 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Room temp sounds good to me
Re: Rock,hard place front main bearing [Re: Clanton] #2310646
05/24/17 10:52 PM
05/24/17 10:52 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The main bearing should measure 2.750 correct?I have used the gauge on the piston bore but not the main.
Re: Rock,hard place front main bearing [Re: Clanton] #2314872
06/01/17 11:01 PM
06/01/17 11:01 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have my block at Victory engines in Cleveland.He measured the crank for me at 2.750" so not much room to the bearing.He will align hone ther block and we have some undersize king bearings on the way.I am making some progress.
Re: Rock,hard place front main bearing [Re: Clanton] #2314932
06/02/17 12:45 AM
06/02/17 12:45 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Good luck.
Re: Rock,hard place front main bearing [Re: Clanton] #2315002
06/02/17 08:42 AM
06/02/17 08:42 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The bearing # is MB5116HP.001 The tech on the phone said the main over bore will take a couple of thou.[crush] and to just watch for fretting on the back of the bearing when going big.
Re: Rock,hard place front main bearing [Re: Clanton] #2315989
06/04/17 03:35 PM
06/04/17 03:35 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Can't beat the cost of an eagle crank. The first thing to do with them is take them to a good grinder and have them turned .01/.01.
Re: Rock,hard place front main bearing [Re: dthemi] #2316018
06/04/17 04:30 PM
06/04/17 04:30 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I still have a chance to mess it up.
Page 3 of 3 1 2 3
