Re: Video from tonight, and some carnage Followed. [Re: Leigh] #231023
02/21/09 10:49 PM
02/21/09 10:49 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
NO offense Curtis, as I say this from 30 years of racing, but, that launch is pretty tame. Something in the setup is hosed. I have raced / watched several thousand passes over the years, and find 2 ring and pinion failures with that car / Dana 60 combo REALLY SUSPECT. Go back to BASICS. Something is amiss.
Leigh
Re: Video from tonight, and some carnage Followed. [Re: afxcoronet] #231024
02/21/09 10:52 PM
02/21/09 10:52 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I would have someone new set up the ring and pinion. I have seen a lot of "Thats close enough" setups brake tons of parts. Sounds to me like not enough preload on the carrier or pinoin bearings or both. Something is moving around. My car has been 1.26 60' with a brake on a Dana 60,4.30 pro gears and stock caps and bolts @ 3170#. Never worn a gear or broke one. I would'nt give up on the Dana.
Bob
Re: Video from tonight, and some carnage Followed. [Re: MoparforLife] #231025
02/21/09 10:53 PM
02/21/09 10:53 PM
Las Vegas
afxcoronet Offline OP
Las Vegas
Leigh
will get it figured out...
Taking over the World one win light at a time.
Re: Video from tonight, and some carnage Followed. [Re: afxcoronet] #231026
02/22/09 12:13 AM
02/22/09 12:13 AM
my own world
theraif Offline
theraif  Offline
my own world
Hey afxcoronet did you get that cat from up north ?
Re: Video from tonight, and some carnage Followed. [Re: theraif] #231027
02/22/09 12:16 AM
02/22/09 12:16 AM
Las Vegas
Las Vegas
I'm originally from WI, and the car has been in the family for a very long time...
Re: Video from tonight, and some carnage Followed. [Re: bad1970dust] #231028
02/22/09 12:37 AM
02/22/09 12:37 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
sounds like you need some one who knows to set up a dana ive got 9 years of 8 sec. abuse on my dana. car weighs 3110. has a 1.27 60 on motor and 1.20 on bottle runs 8.80 on motor 7.70 on gas.rear end has been together for 17 years in the car.not even a bearing change.find a new builder,by the the picture is on the motor no juice!!!!!
I have owned 3 different drag cars with dana 60's and never broke a rearend. Last time out in the daytona (a lot lighter car)broke the ring gear on the ford 9". I always liked the idea of having a spare pumpkin to through in but guess what. I NEVER BOUGHT A SPARE ONE!!!. By the way the ford 9" had all the goodies.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Video from tonight, and some carnage Followed. [Re: pittsburghracer] #231029
02/22/09 01:03 AM
02/22/09 01:03 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
60 here but put new gears in once a year broke or not, just trying to be careful
Post deleted by Defbob [Re: rtstreet] #231030
02/22/09 01:17 AM
02/22/09 01:17 AM
Re: Video from tonight, and some carnage Followed. #231031
02/22/09 02:45 AM
02/22/09 02:45 AM
iowa
bad1970dust Offline
"Hollywood"
bad1970dust  Offline
"Hollywood"
iowa
thanks for the complement on my car yours i cool to i really like the 65s probley my fav b body. my dana has m.w. caps axles and spool with only a crome cover. always been like since i built it.if you have any ? about what the guy is doing to settting it, pm me maybe i can help you and make sure hes doing it right.been doing this for over 20 years narrowed and set up alot of rears.be more than happy to help..
Re: Video from tonight, and some carnage Followed. [Re: afxcoronet] #231032
02/22/09 11:24 AM
02/22/09 11:24 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Last night I was at dinner with some MoPar racing friends of mine. We discussed this post.
Both of them have Danas, one hasn't hit it with enough power YET. (he will soon) The other has a car similar to mine in power, trans brake, etc. he hasn't had any problems with his 60.
He bought the whole thing from Strange ready to go. So they must've set his gears properly.
When I built mine I was backhalving the car and going from 83/4 which I was breaking on a regular basis, especially when I went to a transbrake, even with a backbraced housing, tight setup etc!
I liked the drop out center of the 8.75, Rob @ LRT was doing the backhalf, suggested the fab 9 housing, I have had good service from Strange equipment so now I have 2 centers a spare or I can easily change to experiment.
The moral to the story is; I think either will work fine if they are setup properly!
You already have a Dana and if you know what ratio works best for your combo, stick with it and get it setup properly. I am sure you will have plenty of trouble free runs as others have!! Don
Re: Video from tonight, and some carnage Followed. [Re: cudadon] #231033
02/22/09 02:30 PM
02/22/09 02:30 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Where are you getting the 4.30 gears? Can never seem to find a set.
