Video from tonight, and some carnage Followed.
#231003
02/21/09 01:55 AM
02/21/09 01:55 AM
Posts: 1,151 Las Vegas
afxcoronet
Las Vegas
Well, been making some changes to my car the past few weeks since I've been home and finally made it out. replaced the front shocks w/ a set of AFCO double adjustables, and added a set of Mufflers to it. Ran the best it has ran in years, only made one pass untill the carnage began. With help from Eric Paul(Irun6snd8th)and Troy, I tried some new stuff and finally got the car to react to changes, still waiting on my new torsion bars, but I'm convinced it's moving in the right direction...The first video it went 1.33 60' on a marginal track and ran the best it has in 2 seasons, 6.07 @112, left pretty dang hard... Enjoy the video... Second time run, was still in the wheel stand when I heard the ring and pinion come apart...this is the second set of gears I've broke in this Dana 60, and these are 4.30 Progears...Was told it did an even higher wheel stand in the second run... Gonna replace the dana w/ a Ford 9" I'm done messing w/ this thing, this tranny has bolt in sprag and stuff, so kinda curious how that's gonna look...Then gonna work on the shock tuning a bit to calm it down, just happy it reacted to changes... I'm down, but not for long, gotta keep pushing forward in order to make big things happen... Curtis
Taking over the World one win light at a time.
Re: Video from tonight, and some carnage Followed.
[Re: afxcoronet]
#231004
02/21/09 02:47 AM
02/21/09 02:47 AM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
Car sounds good..Man I miss San Antonio had a great time while there. Good to hear you made it back out after playing in the sandbox. Sorry for the carnage but it dont sound to bad.
[Re: MR_P_BODY]
#231009
02/21/09 10:37 AM
02/21/09 10:37 AM
afxcoronet
Las Vegas
Thanks you all, was rather disappointing. I got a plan, and will be making some phone calls Monday morning, hope to be back out in about 2 weeks w/ a 4.30 geared 9". Hey Kevin, give me a call today... Curtis
[Re: afxcoronet]
#231010
02/21/09 10:57 AM
02/21/09 10:57 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Nice video, car looks good, sounds good and I'm jealous of that launch! You've probably been asked a million times but what's the engine combo and race weight?
[Re: ProSport]
#231012
02/21/09 11:11 AM
02/21/09 11:11 AM
afxcoronet
Las Vegas
Thanks, it's a 14.5-1 compression RB 496 w/ Indy MW EZs done by Dwayne Porter he did the cam as well .630 lift Comp Roller, and Flying toilet, w/ Star Vacuum Pump, this combo has worked very awesome and is very low maintenence, Car weighs 3150 w/ me in it.
[Re: Garceau]
#231013
02/21/09 03:01 PM
02/21/09 03:01 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Its impossible....everyone here will tell you its impossible to break a Dana 60. Even one with pro gears, the girdles, and set up by a professional shop.
Ditch that heavy pig of a rear and put a real racing rear end in it and be done with it.
To the purists, my Fab9 housing and Strange center section have NO ford parts! All are upgraded aftermarket for strength and reliability. I have hundreds of 9.52-9.78 passes on the center, axles, etc. No problems! Don
[Re: cudadon]
#231015
02/21/09 03:08 PM
02/21/09 03:08 PM
cudadon
New Lenox IL
The first pic was on Rob's table @ LRT Chassis after he put the braces and 4 link brkts. Heres one when it's ready to go in the Barracuda! You won't be sorry! IIRC mine cost about $2000-2500 with Strange brakes. Don
[Re: CrAzYMoPaRGuY]
#231016
02/21/09 03:19 PM
02/21/09 03:19 PM
cudadon
New Lenox IL
What center section and parts are you running Don?
Strange aluminum center, the better pinion supp., 35 spl axles, 4.3 pro gears, the bigger bearings in the axle tubes, 5/8" studs, 1350 cm yoke. Stuff like that, and the price wasn't bad for a Fab 9, which is as strong as most of us will ever need. Don
[Re: tjmarcus1]
#231021
02/21/09 10:33 PM
02/21/09 10:33 PM
afxcoronet
Las Vegas
sounds like you need some one who knows to set up a dana ive got 9 years of 8 sec. abuse on my dana. car weighs 3110. has a 1.27 60 on motor and 1.20 on bottle runs 8.80 on motor 7.70 on gas.rear end has been together for 17 years in the car.not even a bearing change.find a new builder,by the the picture is on the motor no juice!!!!!
Thanks, I'm thinking of giving it one more try w/ new builder. Your Car is Awesome, one of my favorites on here...
is that car an 1/8mi. car? if so, why the 4.30's?
We run both 1/8 and 1/4 mile down here, most our bracket races are 1/8 mile, but the Divisionals and national events are 1/4. thinking of going back to the 4.56s though.
Thanks a lot guys, I hope to have the rearend and tranny out tomorrow night. Curtis
