Tire to quarter panel clearance
#2309791
05/23/17 02:26 PM
05/23/17 02:26 PM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
Is there a general rule of thumb as to how much clearance is needed between the tires and quarter panel lip? I just installed new tires on my cuda and they are a little too close for comfort. On the drivers side I can barely get a finger between the lip and on the passenger side I cant even fit a finger between the two. I don't know the measurement off the top of my head but I would say roughly 3/8" to 1/2" clearance on the drivers side and about 1/4" to 3/8" on the passenger side.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Tire to quarter panel clearance
[Re: 73cuda340]
#2309792
05/23/17 02:28 PM
05/23/17 02:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
1/2" is my minimum. Can you roll your fender lip?
[Re: 73cuda340]
#2309808
05/23/17 02:54 PM
05/23/17 02:54 PM
Posts: 1,322 Michigan
crlush
I have 1/2 or less on mine, seems ok i made sure i filed any sharp edges off the lip so if it rubs it doesn't cut anything, when i use wheel dressing on the tires every now and then i can see a witness mark probably from going around corners, but wipes off and you cant see any wear.
[Re: Supercuda]
#2309827
05/23/17 03:22 PM
05/23/17 03:22 PM
73cuda340
clarks summit pa
1/2" is my minimum. Can you roll your fender lip? I'm afraid to roll the lips and ruin the paint on the car. I shaved a little bit off of the quarter panel lips to get this clearance. The car has aftermarket quarters on it so it has the huge lips that were probably 1" to 1 1/2" at first. I shaved them down to get this amount of clearance and then I filed the sharp edges. I'm just afraid to hit a bump in the road or take a sharp corner and the tire will contact the quarter panel and end up buckling it or ruining it.
[Re: Fat_Mike]
#2310291
05/24/17 12:10 PM
05/24/17 12:10 PM
73cuda340
clarks summit pa
Your sidewall height plays the biggest role. What size rims/tires are you running in the rear? The tires are 295/55 15's in the back with cragars that are 15x8 with 4.5" backspacing. I asked around on here before and there were people saying that they run these same exact tires on cudas and they had no clearance issues. I 'm thinking my problem is in the aftermarket quarter panels.
[Re: 73cuda340]
#2310376
05/24/17 02:38 PM
05/24/17 02:38 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
Two other factors is the type of suspension and driving style.
Some suspensions like 4 bar w rubber bushing move sideways alot in hard cornering, leafs too.
Panhard, independant styles are solid. Clearance can be almost nothing.
If you do easy driving,you also can run minimum clearance.
