Swapping slicks around
#2309130
05/22/17 03:22 PM
05/22/17 03:22 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
I've got several events on my Hoosier bias tires now and starting to think about the sidewalls. How many of you guys swap your slicks & run them the other direction? Seems to me it would shorten the sidewall life.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Swapping slicks around
[Re: mikeysmopars]
#2309138
05/22/17 03:29 PM
05/22/17 03:29 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
Two theories here. At this point many will say don't bother now, and I would likely be one of them. If they have 30+ passes on them and you rotate them now they likely they will not be happy for a number passes if at all. The other camp will say rotate them on a regular basis, like every race or two at most. We do rotate ours every 15 passes or so on the dragster and did on the Cuda as well. On the heads up car we do it every three passes. We seem to get a lot of tire life on that car for what it is for sure. I know a lot of people who never rotate their tires as well. I am not sure there is any scientific data to support any of it being better or not, for years many slicks were one directional, so they could not be rotated. I also think it depends on the car, power level and rear suspension type, Ladder bar cars are inherently hard on tires, they have a lot of bite and most are not controlled well. That will kill the sidewall long before the tread is gone.
[Re: Al_Alguire]
#2309444
05/22/17 11:37 PM
05/22/17 11:37 PM
Posts: 784 Liverpool, NY
SILVER67
Liverpool, NY
I don't swap slicks on either car G/F Camaro (factory torque arm) or my Coronet (multi-leaf)
She killed the sidewall's on her Hoosier QTP's with 1.51-1.54 sixty foot on a 10.90 car. But she double classes weeky. She's on the 3754x now
My Coronet gives the M/T Radial's a workout but thats more of the weight than the power. 3,950 and sixty foots in the 1.57-1.61 They been in use since 2015
Any Mickey radial i used worked the same until the cords were showing. Think the radial's are directional tho Her's has 10" rim and 10" tread I have 7" rim and 9" tread
Prob different need for tire rotation on a 10.0 car i'd imagine
[Re: mikeysmopars]
#2309521
05/23/17 01:35 AM
05/23/17 01:35 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
It looks like your car hits the tire pretty hard, No expert here , I don't rotate, It would seem to me it might give you longer tread life but the reversing of the sidewall thread direction would total out the side walls before they were worn out
[Re: mikeysmopars]
#2309729
05/23/17 12:53 PM
05/23/17 12:53 PM
Al_Alguire
Las Vegas
More air will put more tire on the ground, wont be the fast way for sure.
If you want my opinion, and you did not ask for it but here goes. I can see from that pic you need a WAY STIFFER shock on the back of that thing. It works well but it is killing the sidewall. Tubes can also help, I don't think Hoosier makes a stiff sidewall that size. Mickey does and IMO just about every ladder bar car out there can benefit from stiff sidewalls and or tubes. Or better yet a stiff sidewall tire and a beadlock wheel. But just my .02 on the picture...
[Re: J_BODY]
#2309783
05/23/17 02:09 PM
05/23/17 02:09 PM
mikeysmopars
fresno ca
I'm Jay....and I'm a slick swapper. Somehow I new that
[Re: Al_Alguire]
#2309796
05/23/17 02:34 PM
05/23/17 02:34 PM
mikeysmopars
fresno ca
If you want my opinion, and you did not ask for it but here goes. I can see from that pic you need a WAY STIFFER shock on the back of that thing. It works well but it is killing the sidewall. Tubes can also help, I don't think Hoosier makes a stiff sidewall that size. Mickey does and IMO just about every ladder bar car out there can benefit from stiff sidewalls and or tubes. Or better yet a stiff sidewall tire and a beadlock wheel. But just my .02 on the picture... Thanks Al I do run tubes and use to run 15 lbs footbraking it with no issues. With all the changes and transbrake I'm still playing catch-up With my combo. Most air I've been able to run so far is 12 lbs.without chattering. That pic was 11 lbs and if I can zero in on shock adjustments I should be able bring the air pressure back up.
[Re: mikeysmopars]
#2309814
05/23/17 03:05 PM
05/23/17 03:05 PM
Al_Alguire
Las Vegas
Well you don't necessarily need more air. You need the amount of air that track conditions dictate. The better the track the less air you can run, conversely the worse the track conditions the more air you need. When the track is poor you need as much contact patch as possible. MOre air will do just that, as the rear end housing is pushed down the tire will flatten out giving you more contact patch. Less air for a tight track will allow the tire to cup in the center and give you less tire on the ground, giving you more wheelspeed. It is chattering cause there is not enough power to overcome that with the full tread making contact. You need to tighten the extension and lower the air pressure to overcome that...
[Re: Al_Alguire]
#2309885
05/23/17 04:39 PM
05/23/17 04:39 PM
Posts: 1,111 Usa
A39Coronet
Usa
Well you don't necessarily need more air. You need the amount of air that track conditions dictate. Correct. The better the track the less air you can run, conversely the worse the track conditions the more air you need. When the track is poor you need as much contact patch as possible. MOre air will do just that, as the rear end housing is pushed down the tire will flatten out giving you more contact patch. Less air for a tight track will allow the tire to cup in the center and give you less tire on the ground, giving you more wheelspeed. Uhh...what? The better the track, the MORE air you can run. Your goal should be the most air pressure you can get away with. This keeps the sidewalls from killing themselves, and keeps the car happy at the other end. When the track is cool and tight, you should be able to run much more pressure than compared to a hot greasy day.
[Re: mikeysmopars]
#2309897
05/23/17 05:10 PM
05/23/17 05:10 PM
Al_Alguire
Las Vegas
Exactly backwards...But what do I know. Hit the tire to hard it will shake or try to drive over itself as there is not the power available to drive through it. Letting air out allows the tire to cup at the hit and less tire Is in the track, basic physics. Fist move of the tire is DOWN. The more air you have in that tire the more of a contact patch you have on the ground during that first move. On a good track you will wad the tire up and if you have any power at all will shake the tire. TO solve that on a good track take out air and tighten the shocks. On a bad, hot, greasy track you want to run less shock and more air..
[Re: mikeysmopars]
#2309900
05/23/17 05:13 PM
05/23/17 05:13 PM
Al_Alguire
Las Vegas
SHOCKS control the hit on the tire not air. We run 5lbs of air and you will hardle see a wrinkle on our car. On the small tire heads up car on a good track we will run as little as 9lbs on a 29.52x10.5 with a very stiff shock setting and one again you will hardly see a wrinkle in the tire. When the track get hot and greasy we will run 9.75-10lbs and loosen the shocks to get more rubber on the ground. This car is usually in the 1.12-1.15 60' range with a SB no power adder deal. My sons car goes 1.04 60' on a 13.5" slick
The idea of as much air as you can is old school slow thinking. Wheelspeed is what gets a car QUICKLY down a track. Tubes will help a sidewall as will a beadlock. Most importantly a GOOD shock will keep the sidewall alive. Cheap shocks with inadequate valving will kill a sidewall in a hurry. I understand the thought process you are using and used to think that way myself years ago. I have grown and learned over the years what works and what does not.
[Re: mikeysmopars]
#2309907
05/23/17 05:23 PM
05/23/17 05:23 PM
Al_Alguire
Las Vegas
This is what happens with to much air and not enough shock. And this is not a bad one 5.5lbs and 2 from full stiff https://www.youtube.com/watch?v=3Hslwkm9zpsThis is the same track same day with 1/4lb less air and two clicks in the shcoks. The track was very tight this weekend and we just misread the track first pass. This was a 1.044 60' pass 5.25lbs full stiff. We need to get some stiffer shocks as we are out of valving now with this engine. Once we handle that there will be NO wrinkle and the 60's will dropout https://www.youtube.com/watch?v=tF4QXmXRqU4Using dragster video as it's easier to see the affects.
