Re: 5.9 magnum build sqr deck block .070 or buy kb107 &balance?
[Re: dogdays]
#2309236
05/22/17 06:29 PM
05/22/17 06:29 PM
RapidRobert
Every Dog has its day!. I would see how far in the hole you are right now for a baseline/start.
[Re: mgoblue9798]
#2310715
05/25/17 01:22 AM
05/25/17 01:22 AM
Posts: 184 Memphis,TN
J. Hammer
Memphis,TN
I'm not sure why you'd do either? Sounds like a street/daily driver? The issue is the lack of valve reliefs(not a problem for your situation). Put a thin head gasket on it(if you want a bit more comp)and go. The stock pistons are approx .050" in the hole,no big deal.
[Re: Pale_Roader]
#2310768
05/25/17 06:15 AM
05/25/17 06:15 AM
J. Hammer
Memphis,TN
LOL I got that. Id guess as a 40yr veteran mopar racer I'd ask where are the important gains in any build? "quench" is waaay down the list,but on this site its just like gold(lol),not close and Id gladly give a point of comp for the better ring pack of the factory piston all day. We have made over 600hp on the factory junk short block,yep it only made it 6yrs but it had no quench.lol Some folks would trip over a nickel and miss a quarter.
[Re: HotRodDave]
#2312144
05/27/17 09:41 PM
05/27/17 09:41 PM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
My 318 magnum I went from the factory .086 quench distance to .038 made it ping a lot less as well as better MPG TQ and HP. That was the only change at that time, I even took it to LA and pulled a car up those big hills on my open trailer at sea leval and no pinging on 87 octane california crap gas. After that experiment I am a big fan of maximizing quench area and minimizing quench distance. My goal with this 2000 360 Magnum i just bought is .030" quench. Might take some decking... but i paid very little for the engine, so i think its worth an experiment. I kinda wanted to go with the 318... seemed a better choice for less machining, more tolerance, better piston shape... many details... but i just got such a sick deal on this 360 i couldn't pass it up. 360view... i think you'd just be better off with the machining. Thats a lot of thickness to ask from coatings and such... and (it would seem to me at least) a little hokey.
[Re: HotRodDave]
#2312183
05/28/17 12:18 AM
05/28/17 12:18 AM
RapidRobert
My 318 magnum I went from the factory .086 quench distance to .038 made it ping a lot less as well as better MPG TQ and HP. That was the only change at that time, I even took it to LA and pulled a car up those big hills on my open trailer at sea leval and no pinging on 87 octane california crap gas. After that experiment I am a big fan of maximizing quench area and minimizing quench distance. What was your SCR before and after? & nothing else was changed/adjusted/altered?
[Re: mgoblue9798]
#2313798
05/30/17 09:00 PM
05/30/17 09:00 PM
RapidRobert
You got good quench/went from 9-1 to 10-1 & more power/no pinging on 87/no other changes. that is incredible! what a success. Makes a believer out of me.
[Re: RapidRobert]
#2314039
05/31/17 05:10 AM
05/31/17 05:10 AM
Pale_Roader
Swears too much
Swears too much
You got good quench/went from 9-1 to 10-1 & more power/no pinging on 87/no other changes. that is incredible! what a success. Makes a believer out of me. Me too... i think its worth the machining. We're not talking numbers 340's here... screw one up, you're out a couple hundred bucks and the machining.
