727 front drum recomendation? #230875
02/20/09 10:22 PM
02/20/09 10:22 PM
oregon
greendart408 Offline OP
oregon
While I am freshening my 727 I am going to buy a new front drum. 3050lbs, 408sb, 727 with brake and low band apply vb. What do you guys in the know suggest? Alum? billet steel? I only want to buy it once so I was leaning towards the billet steel. Thanks
Re: 727 front drum recomendation? [Re: greendart408] #230876
02/20/09 10:26 PM
02/20/09 10:26 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I would only get the alum drum if you were concerned about saving every last gram of rotating weight. It's lighter, but requires more frequent band adjustments and fluid changes.
Sounds like the billet steel drum would be right up your alley.
Re: 727 front drum recomendation? [Re: greendart408] #230877
02/20/09 10:27 PM
02/20/09 10:27 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
In almost every application except ALL OUT RACE, I would say steel drum from TCS or other similar supplier. I think they are about 600 bucks with a billit 15 spring piston. I think they are Stronger than the aluminum drums anyway.
Don.
Re: 727 front drum recomendation? [Re: greendart408] #230878
02/20/09 10:27 PM
02/20/09 10:27 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I bought the billet drum from rick at a and a transmission
If in doubt, talk to rick, and he will tell you. He is very friendly, and very knowledgable.
Re: 727 front drum recomendation? [Re: dave571] #230879
02/20/09 10:48 PM
02/20/09 10:48 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I got an aluminum one and would never get one again.
got to change fluid every 25 runs and if it made .01 difference I would be suprised. I may buy a steel billet for this year.
Re: 727 front drum recomendation? [Re: greendart408] #230880
02/20/09 11:24 PM
02/20/09 11:24 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I spent the extra $ for the aluminum drum with steel outer sleeve. It came with the billet alum piston and I was able to get 6 discs in it.
Re: 727 front drum recomendation? [Re: @#$%&*!] #230881
02/21/09 12:17 AM
02/21/09 12:17 AM
NW Pa.
KD800X Offline
KD800X  Offline
NW Pa.
We are running an A&A Aluminum drum. Very happy with it. We are also running Mobile 1 trans fluid. Changed the fluid after 25-30 passes and the fluid looked almost new.
WE are not using a trans brake though, I don't know if that would make a difference or not.
