need cam and gearing help #2308600
05/21/17 05:11 PM
05/21/17 05:11 PM
ohio
CumminsExpress Offline OP
ohio
hi everyone sorry did not spend much time searching.
78 volare
cal tracks
alter k front
4 inch strocker
ported edelbrock heads
10.5 to 1
T56 (6th gear .50)
28 inch tall tire
Ford nine inch
any suggestions for Cam and gearing
hopping to do a little auto crose
Thanks George
Re: need cam and gearing help [Re: CumminsExpress] #2308623
05/21/17 06:19 PM
05/21/17 06:19 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I don't like a real lopey cam. And want something very street friendly.
I went with a comp 274-S on my 416 stroker. Still a ton of torque for an autox even with my single plane intake.
With a six speed trans, you have a tone of gear choice. More like what you want your overdrive cruise overall rpm to be.
In an autox you might want to try to lug it a little so not to break the rear tires loose.
Re: need cam and gearing help [Re: CumminsExpress] #2308809
05/21/17 11:01 PM
05/21/17 11:01 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
For Solo II (autocross) 62 - 65 in second gear is where you want to be. Speed Calc
Main Calc page
Just try different gear ratios to see what your speed will be in second gear. Then you can see what your RPM will be in 6th at highway speeds. Now you can look and see what different gear ratios will do. This will give you an idea on what your looking at but with good HP you can move of that and hurt your self much if at all. The Corvettes that rule AS class hit like 72 MPH.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: need cam and gearing help [Re: CumminsExpress] #2309285
05/22/17 07:54 PM
05/22/17 07:54 PM
ohio
ohio
Thanks guys
