Rock,hard place front main bearing
#2308593
05/21/17 04:51 PM
05/21/17 04:51 PM
Posts: 4,488 northern,Ohio,USA
Clanton
northern,Ohio,USA
I have cross bolt mains 1,2,3,4,5 and I need to check #1 but the oil pump is in the way of the side bolt and factory steering box limits oil pump removal.I think I can drop the pump 1/2" to loosen the side bolt and then the main stud to check if the bearing is still tight after that.
Re: Rock,hard place front main bearing
[Re: Clanton]
#2308638
05/21/17 07:01 PM
05/21/17 07:01 PM
Posts: 7,471 Minnesota
Hemi_Joel
Minnesota
I have removed the oil pump before with the engine in the car. I can't remember the exact proscess, but I think I had to jack up the drivers side of the motor, and then back out the bolts but leave them in the pump.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: jlatessa]
#2309082
05/22/17 02:18 PM
05/22/17 02:18 PM
Clanton
northern,Ohio,USA
If I remember right, when I removed the pump to install a high volume kit , I removed the pump cover first, then the body and rotor and installed in the reverse order, didn't have to jack the engine.
Joe BINGO! I just did that,Thank you.Now I have a clear shot at it all.
[Re: Clanton]
#2309146
05/22/17 03:39 PM
05/22/17 03:39 PM
Clanton
northern,Ohio,USA
Well it is looking like I rolled an oil ring putting it together,The main,rod bearings look perfect[almost,lol] on #1main,rod.The squeak is coming from #1 it sounds like and I could pull that head but if you have an idea to test let me know.
[Re: Clanton]
#2309161
05/22/17 04:08 PM
05/22/17 04:08 PM
Posts: 2,289 NE Ohio
DoubleD
NE Ohio
I know some of you will say just pull the darn engine but I take this as a learning exercise,opportunity Yep a lesson in why you did not pull the engine! but I am guessing you already figured it would have been easier to do that. Doing an in line re-build should only be reserved for a big diesel engine or something that runs on NITRO
[Re: DoubleD]
#2309163
05/22/17 04:10 PM
05/22/17 04:10 PM
Clanton
northern,Ohio,USA
I know some of you will say just pull the darn engine but I take this as a learning exercise,opportunity Yep a lesson in why you did not pull the engine! but I am guessing you already figured it would have been easier to do that. Doing an in line re-build should only be reserved for a big diesel engine or something that runs on NITRO My choice and I can live with it.
[Re: Clanton]
#2309175
05/22/17 04:32 PM
05/22/17 04:32 PM
Clanton
northern,Ohio,USA
Well I need a line hone,the top half of the bearing is black on 2/3 of it on a 3/4 groove bearing and by the tab is ok.So now we know and thanks for listening.
[Re: Clanton]
#2309203
05/22/17 05:31 PM
05/22/17 05:31 PM
Clanton
northern,Ohio,USA
There is a high spot at the oil hole and a mark on the back of the bearing from the raised spot so I am sure the others are like that.I had the same issue with the cam bearings!!!!!
[Re: Clanton]
#2309206
05/22/17 05:37 PM
05/22/17 05:37 PM
Posts: 2,175 Duloc
The Shadow
Duloc
[Re: Clanton]
#2309355
05/22/17 09:40 PM
05/22/17 09:40 PM
Clanton
northern,Ohio,USA
"thrust tight" mean? I hit the crank forward and back and it was still tight.lol I think it checked at like .004
[Re: Clanton]
#2309445
05/22/17 11:40 PM
05/22/17 11:40 PM
Posts: 9,791 MI, usa
dvw
MI, usa
"thrust tight" mean? I hit the crank forward and back and it was still tight.lol I think it checked at like .004 If it had .004" endplay what do mean "it was tight,lol"? Did it feel tight when rotated by hand? Doug
[Re: dvw]
#2309603
05/23/17 08:33 AM
05/23/17 08:33 AM
Clanton
northern,Ohio,USA
"thrust tight" mean? I hit the crank forward and back and it was still tight.lol I think it checked at like .004 If it had .004" endplay what do mean "it was tight,lol"? Did it feel tight when rotated by hand? Doug Yes it was tight turning the crank with no rods or pistons in it so Yes I screwed up by going ahead.I should be able to get it line honed and get things moving smoothly.I hope the other mains did not mess up the crank so it can just be polished.Wait and see how things work out I can use these to help maybe.What do you think? https://www.summitracing.com/parts/slp-142m1/overview/make/chrysler
[Re: Clanton]
#2309613
05/23/17 09:21 AM
05/23/17 09:21 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
would hold off buying any parts untill the machine work is done,then discuss it with your machinist.
[Re: Clanton]
#2309821
05/23/17 03:17 PM
05/23/17 03:17 PM
Posts: 4,254 Canada
WO23Coronet
Canada
So this raised spot that every main has by the oil hole, is this from machining/drilling the oil holes/galleries on the mains, almost like a burr? If so you might not need an align hone, hitting each with a radius'd small hone and working them out by hand might suffice. Id think bad main alignment would've even should up with the looser clearances? You take away .001 to .0015" and now it's to tight? I'd get rid of the burrs (if that's what they are), polish the snot out of the crank and get your .004" bearing clearance back.
[Re: Clanton]
#2309910
05/23/17 05:27 PM
05/23/17 05:27 PM
Clanton
northern,Ohio,USA
Maybe some dye on the area and rub a bearing across it to check or partial bearing with emery cloth lightly.The oil hole is drilled from the crank to the cam so why it is raised idk. ps:the bearing is black for 3/4" on both sides of the oil hole with some along the 3/4 groove on the trailing edge.[fyi]
[Re: Clanton]
#2310269
05/24/17 11:27 AM
05/24/17 11:27 AM
Clanton
northern,Ohio,USA
Thank you for your help on this Everyone!!!Roush did the machine work on the as cast block and as in the past with the oil hole in the cam it is high so if it was honed it did not take it out.I set the thrust after I tq'd the mains.I only did a quick check on the crank and the shop that balanced it I guess never looked.[not that I asked]I will go over it better now[a little late I know] ps: the killer is I asked the engine shop that honed the block to align hone it and they did not want to.[long story]
[Re: Clanton]
#2310443
05/24/17 04:45 PM
05/24/17 04:45 PM
Clanton
northern,Ohio,USA
What the heck!?I have it down to the crank with pistons in and it only takes 28 ft lbs to turn it.I noticed it after removing the cam timing chain.I need to hold up here and ponder this.This does not change that the bearing is burned!!!
[Re: Clanton]
#2310452
05/24/17 05:04 PM
05/24/17 05:04 PM
Clanton
northern,Ohio,USA
1 of the 1st things to do is put the #1 main on and see if it is tight again.I noticed something else,The TC nose has the paint off of it and I wonder if the trans is pushing on the crank making the thrust tight in turn making the engine hard to turn by hand.I will get to checking the thrust bearing and the back of it after checking the engine good.I am open for ideas on the order to check things!!!!
[Re: Clanton]
#2310551
05/24/17 08:05 PM
05/24/17 08:05 PM
Clanton
northern,Ohio,USA
Some good news is all the rods,pistonbores look good.1,2,3 main have just a littler heat in them on the block side and not over the oil hole.I will have the crank measured to start and to be honest I think the .001 under bearings will do the trick but we will see. Thanks for listening.ttyl ps:The thrust was .006 with a dial on it.
[Re: Clanton]
#2310646
05/24/17 10:52 PM
05/24/17 10:52 PM
Clanton
northern,Ohio,USA
The main bearing should measure 2.750 correct?I have used the gauge on the piston bore but not the main.
[Re: Clanton]
#2315002
06/02/17 08:42 AM
06/02/17 08:42 AM
Clanton
northern,Ohio,USA
The bearing # is MB5116HP.001 The tech on the phone said the main over bore will take a couple of thou.[crush] and to just watch for fretting on the back of the bearing when going big.
[Re: dthemi]
#2316018
06/04/17 04:30 PM
06/04/17 04:30 PM
Clanton
northern,Ohio,USA
Can't beat the cost of an eagle crank. The first thing to do with them is take them to a good grinder and have them turned .01/.01. I still have a chance to mess it up.
