Post deleted by Defbob
[Re: Scamp451]
#230777
02/20/09 09:07 PM
02/20/09 09:07 PM
Re: Pro stock block question
#230778
02/20/09 09:21 PM
02/20/09 09:21 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
The blocks that NHRA ruled against were actual GM blocks.They were cast for them by Caterpillar.Mopar at the time was assigning Mopar P/N's to GM parts in order to make things "legal".I have pictures of Nickens "Mopar" engine in the back of a Dodge truck on a dolly and ones in the Avengers,and they are without any doubt GM engines.
The original version of the B-1 engine(1987-88) may have been Keith Black,but were cast.The later blocks were RJ and C&S made blocks.
[Re: Defbob]
#230781
02/20/09 10:29 PM
02/20/09 10:29 PM
Posts: 6,136 Melbourne , Australia
LA360
The Phoenix blocks had splayed caps like a Chevy block, who they were cast by I have no idea. I do recall the Eicke engine basically being a Chevy engine with Mopar Part numbers.
At that kind of level of power, alot of the engines would end up being very similar anyway. AL....
Alan Jones
[Re: AndyF]
#230789
02/21/09 02:40 AM
02/21/09 02:40 AM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
Just for grins and giggles here is a current Pro Stock block, along with some other stuff. Thought they were cool..BTW note the cam journal size against the main bearing size Cams for comparisons sake. Current PS in the foreground, typical roller in middle and a 55mm in the rear. How about a crank shot New design 99 Hemi valve cover
[Re: AndyF]
#230792
02/21/09 09:47 AM
02/21/09 09:47 AM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
When the starter is on the passenger side and there isn't any distributor hole up front you start to think it might not be a Mopar block.
those are the T/S heads right?
[Re: AndyF]
#230796
02/22/09 12:09 AM
02/22/09 12:09 AM
Posts: 1,340 Pennsylvania
proshiftcharger
Pennsylvania
Heres a pic of a HEMI PS motor starter location (drivers side)
[Re: proshiftcharger]
#230798
02/22/09 12:35 AM
02/22/09 12:35 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
Actually, when NHRA paid attention to blocks used, it was the "factory teams" that suffered, A. Johnsn was using a different block made by a other supplier totally by aftermarket. The problem with the denied block was that it actually came from the same line as GM "factory" PS blocks. In a typical pro stock engine you just don't go to a speed shop and buy a block, it takes A LOT of effort and changes to build one for use. Currently the mopar block is told to be about the "readiest" block on market. Personally I have not seen anyt Eicke stuff. When they went with the 4.9" bore space, everything used "GM blocks", All the stuff I have seen is B1/TS parts for those. I believe there wasnt much performance difference at that point, but Eicke that co-operated with Steve Schmidt already had a working PS program with the GM, and there was kind of a temptation.... Hasn't been much talk about Eicke lately, was kind of beried with the mopar deal but was a main player before that. I can have my hands on a pretty late B1/TS engine (Steve Schmidt/Billy Stepp), good power, but pretty "thin" comapred to csame era GM's, narrower powerband. And you need a guy from Finland to write this.
Plynouth VIP '67 TT IC EFI
