metal sparkles in trans pan? #230768
02/20/09 08:14 PM
02/20/09 08:14 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
I just pulled the pan of my 727 to find what you typically find in a 727's pan with 3000 miles on it when I also noticed some very fine brass or bronze particles also. where is that from
Re: metal sparkles in trans pan? [Re: ccdave] #230769
02/20/09 08:56 PM
02/20/09 08:56 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
brass or bronze would be from a bushing or a thrust washer
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: metal sparkles in trans pan? [Re: dusturbd340W5] #230770
02/20/09 10:35 PM
02/20/09 10:35 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
Was it all over the place or was it in a little pile about the size of a nickel? Alot of times that can be normal wear and tear. 3000 miles on my Challenger is probably 300,000 in regular miles .
Don.
Re: metal sparkles in trans pan? [Re: MoparDonny] #230771
02/20/09 10:55 PM
02/20/09 10:55 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
A little bit of metal sprinkles in a low mileage trans is normal. A picture would help.
Re: metal sparkles in trans pan? [Re: 69Cuda340S] #230772
02/20/09 11:30 PM
02/20/09 11:30 PM
Alexandria, VA
SealockRacing Offline
Alexandria, VA
probably all of the parts wearing into each other. like breaking in...
think of it like changing the oil after breaking a motor in, and checking the filter..., kind of like that?
Re: metal sparkles in trans pan? [Re: ccdave] #230773
02/21/09 10:02 AM
02/21/09 10:02 AM
Camp Point, IL
gofish Offline
gofish  Offline
Camp Point, IL
When I rebuilt my 727, I had the pan back off to change converters after 30 or 40 passes down the track. It had a pretty liberal amount of "stuff" in the pan. I was told that was normal for a new rebuild. I put it back together and ran another 50 or so passes and took the pan back off. Still had a bit of metal filings in the "mud" in the bottom, but nothing like the first time. I ran another 200 passes and took the pan back off and there was a small amount of "stuff" in the bottom, but much less than before. It looked to me like the parts were just getting broke-in with 300 passes. This was in a very low HP, heavy bracket car, YMMV.
Danny
