Is super sprag needed ????
#230751
02/20/09 08:13 PM
02/20/09 08:13 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
I'm getting my new 418 going . My ?? is have you used a SUPER SPRAG verses the standard bolt in sprag. With the extra rollers and springs have you saved the cases more and do you need the template for drilling this in? I'm going to update to a 1350 ujoint DRIVE SHAFT setup and billet yoke and slip yoke to beef up the driveline more. After that will that griner lba brake save the trans even more???Or one over the other ? i have a old griner from mid 1990s looking for 1.30 to 1.32 60ft low gear 727 thanks don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
Re: Is super sprag needed ????
[Re: Leigh]
#230753
02/20/09 08:36 PM
02/20/09 08:36 PM
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
So 3 pcs would be more durable ,steel alum drum mines not a LBA brake yet and a supersprag. don
new 9.96 131.82
6.23 108
1.30 60 foot
[Re: 10 o to go]
#230754
02/21/09 08:55 AM
02/21/09 08:55 AM
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
so other threads posted looks like a steel drum is in the works also . from what i'm reading the LBA brake holds the sprag better don
new 9.96 131.82
6.23 108
1.30 60 foot
[Re: 440Jim]
#230758
02/21/09 06:37 PM
02/21/09 06:37 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
To me, it comes down to three ways of thinking:
1) Throw parts at it to prevent sprag failure.
2) Let the sprag fail and replace the part that actually explodes (the front drum) with a less explosion prone part.
3) Do both.
Of course, budget controls the ultimate decision.
[Re: John_Kunkel]
#230760
02/21/09 09:48 PM
02/21/09 09:48 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
3) Do both.
GOOD points and very rational thinking ....
Since my car I am working on now(I will be sitting with my legs on either side of the trans) ... my vote is to go with ONLY the aluminum drum.
I have done MORE than my share of 727's ....and I have only seen 2? sprag failures ...and those failures did not hurt the trans itself(other than the sprag needing to be replaced).
[Re: DJVCuda]
#230762
02/21/09 10:14 PM
02/21/09 10:14 PM
dOc !
Florida STAYcation
This is member PLUM BAD's pix.... his foot is where your nuts are going to be, do they make casts for nuts?
]http://i173.photobucket.com/albums/w43/PLUM1320/Transmission/img002.jpg [/image]
Huh ? .. ?? .... with an aluminum drum ... there is NO WAY to make the trans explode ...even if you wanted it to !
[Re: Leigh]
#230765
02/21/09 11:52 PM
02/21/09 11:52 PM
Posts: 15,478 the boonies
aarcuda
the boonies
I use them in higher horsepower street cars with automatic shifted valve bodies and strip cars with non low band apply valve bodies. If yours isn't a low band apply, get a steel or aluminum drum and use it in conjunction. It's a durable combo.
if i was doing mine, i'd run both the super sprag and the steel drum. it can only help, right?
[Re: DJVCuda]
#230766
02/21/09 11:53 PM
02/21/09 11:53 PM
aarcuda
the boonies
there is an 8 page writeup in this months Mopar Enthusiast covering exactly what your asking - shows the differences and gives you enough information to make a educated decision. John Cope from CRT was instrumental in the articles factual information.
i read that today. its a great article. a keeper for sure!
[Re: aarcuda]
#230767
02/22/09 12:33 AM
02/22/09 12:33 AM
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
guys thanks for your opinions and thoughts on what to do to a trans to minimize the danger and make a trans live longer . ussaully when i brake sprag it has split the case TROY glad you made us at least aware of the subject more . Is the LBA brake install any different than not a LBA and also steel drum . thanks don
new 9.96 131.82
6.23 108
1.30 60 foot
