Aluminum Drum Band Adj.? #230675
02/20/09 07:06 PM
02/20/09 07:06 PM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
I'm sure this has been answered before but with my elephantine memory I just can't remember. What's the correct band adjustment using an Aluminum front drum? Is it different than the iron or steel units?
I'm going up to balmy Key West tomorrow (where's the penguin under the palm tree icon when you need it?) to help Maxumus Wedges swap out a low gear set on his TF race unit. Dave
Re: Aluminum Drum Band Adj.? [Re: quickd100] #230676
02/20/09 08:30 PM
02/20/09 08:30 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
I don't adjust mine any different than from a steel unit. It has always worked well for me.
Re: Aluminum Drum Band Adj.? [Re: SuperStocker] #230677
02/20/09 08:40 PM
02/20/09 08:40 PM
CT
turbocolt2.4L Offline
CT
no different than a steel drum i usually go 1 1/4 with the 4.2 ratio arm.
Re: Aluminum Drum Band Adj.? [Re: SuperStocker] #230678
02/20/09 08:40 PM
02/20/09 08:40 PM
nielsville, minn.
Q
Q
nielsville, minn.
Thanks Ryan, that's all I needed to know . Dave
Re: Aluminum Drum Band Adj.? [Re: quickd100] #230679
02/21/09 12:28 AM
02/21/09 12:28 AM
NW Pa.
KD800X Offline
KD800X  Offline
NW Pa.
I think Rick Allison told me to tighten it to 70 inch pounds then back off a 1/4 turn.
