69 Roadrunner 5.7 hemi swap header or manifold questions #2306475
05/18/17 02:14 AM
05/18/17 02:14 AM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
We are putting a 08 hemi in my dads gtx and I was wondering about where to go for his headers or more preferably manifolds. I have seen people with tti's having to rent them up and I don't want to buy them to beat on them. I have built a few sets of headers and will just do that if it comes to it but would just rather get some stock manifolds to work. He has the Schumacher swap mounts and is running a 833 trans if that matters.
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
Re: 69 Roadrunner 5.7 hemi swap header or manifold questions [Re: haddixj] #2306715
05/18/17 01:52 PM
05/18/17 01:52 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
We put 5.7 Hemi engines in an E-Body Challenger and a TJ Jeep Wrangler and we used '05-'07 Jeep Grand Cherokee 5.7 Hemi exhaust manifolds in each and they fit nice and compact...
SuperBeast
An enforcer for the Mopar Mafia!
Re: 69 Roadrunner 5.7 hemi swap header or manifold questions [Re: haddixj] #2306743
05/18/17 02:32 PM
05/18/17 02:32 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I used long tube headers with no fitment issues at all in the past, but I can't remember which brand now. The advantage to headers is you can easily buy an exhaust from headers back to fit where if you use manifolds, your going to have to do custom exhaust work.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 69 Roadrunner 5.7 hemi swap header or manifold questions [Re: haddixj] #2306999
05/18/17 09:14 PM
05/18/17 09:14 PM
Scottsdale, AZ
K
kenz Offline
kenz  Offline
K
Scottsdale, AZ
Check out part # 77072462. Supposed to be for dropping Gen III Hemi's into classic cars.
I found out about these when looking at the new controllers Mopar released recently.
Hope it helps.
Mopars Unlimited of Arizona
www.moparsaz.com
Re: 69 Roadrunner 5.7 hemi swap header or manifold questions [Re: haddixj] #2307312
05/19/17 12:39 PM
05/19/17 12:39 PM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
Thanks for the part number I will check them out
Re: 69 Roadrunner 5.7 hemi swap header or manifold questions [Re: haddixj] #2307361
05/19/17 02:28 PM
05/19/17 02:28 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Like I mentioned above, you still need to do some custom exhaust... there are cheap stock options if you do some research. One nice thing with new hemis is no more messing with headers in the way of spark plugs.
Re: 69 Roadrunner 5.7 hemi swap header or manifold questions [Re: Silver70] #2307378
05/19/17 02:58 PM
05/19/17 02:58 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
AMEN TO THAT
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
