383 HP 330vs335 hp
#2305673
05/16/17 08:37 PM
05/16/17 08:37 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
I know the Superbee/RR 383 HP got a diff camshaft than the 383 HP Magnum/supercomando used on the Charger, Coronet, Satellite and as far I know is the only difference, but what are the spec on them?
Is the lower of the purpleshaft cams correct for the 330 or to the 335 hp engine?
Re: 383 HP 330vs335 hp
[Re: NachoRT74]
#2305679
05/16/17 08:43 PM
05/16/17 08:43 PM
NachoRT74
Valencia, España
440 heads? Different from the 383?
[Re: NachoRT74]
#2305706
05/16/17 09:38 PM
05/16/17 09:38 PM
NachoRT74
Valencia, España
Ok, would like to know the specs on diff parts between the 330 and the 335 horse power engines
Diff exhaust manifolds between them? I know diff with 2 bbls but being both 4 bbls ? I guess both were called magnum as well ( Dodge )
[Re: elmor353]
#2305753
05/16/17 10:48 PM
05/16/17 10:48 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
. 68 to 71 383's all used the same heads as 440's. No they don't. 68-70 are the same 906 heads, 1971 are 3462346 heads
[Re: elmor353]
#2305757
05/16/17 10:51 PM
05/16/17 10:51 PM
NANKET
northwest USA
335 hp engines usually got the HP exhaust manifolds, while the 330 hp engines usually got logs like the 2bbls. No they did not get log manifolds. The 383 4 bbl engines absolutely have HP manifolds 1968-1971, The 1967 and older 383 4 BBl engines in B and C bodies got log manifolds.
[Re: NachoRT74]
#2305760
05/16/17 10:55 PM
05/16/17 10:55 PM
NachoRT74
Valencia, España
Well, I'm looking at several 68/70 Charger engine bays with 383 Magnum and I can see HP manifold exhaust on everyone
[Re: 68mannix]
#2305783
05/16/17 11:29 PM
05/16/17 11:29 PM
Posts: 727 Michigan
BlueRacer69
the difference is that the 335 horse engine got a windage tray and the 330 horse engine did not that's the 5 horse difference. Not true. My 69 383 Dart GTS with 330hp had the windage tray in the oil pan from day one. And I'm the original owner.
[Re: BlueRacer69]
#2305789
05/16/17 11:38 PM
05/16/17 11:38 PM
Posts: 43,112 Bend,OR USA
Cab_Burge
Mopar derated the HP on all the 383 A body engines(300 or maybe 305 HP) supposedly due to the driver side exhaust manifold, so they said Me thinks that the 335 HP rated 390 FE Mustang and Fairlane GT and the 1968 1968 and up 428 ford motors ratings of 330 and 335 HP had a lot of input on Mopars decision on those A body HP rating Epecially the 275 HP 340 motors
