Page 3 of 3 1 2 3
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2305318
05/16/17 02:11 AM
05/16/17 02:11 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I'd make sure the fuel pressure isn't too high, blowing by the needle and seat.
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2305331
05/16/17 02:46 AM
05/16/17 02:46 AM
Tacoma, Washington USA
Adam71Charger Offline OP
Are small 2 barrel holleys pretty common on fuel pressure requirements? I can get a refulator if necessary, what should the psi be?
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2305457
05/16/17 12:47 PM
05/16/17 12:47 PM
So. Burlington, Vt.
So. Burlington, Vt.
About 4.5-5.5psi.
Re: Clogged pick-up or oil pump failing? [Re: fast68plymouth] #2305663
05/16/17 08:23 PM
05/16/17 08:23 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Having fuel in the crankcase will thin the oil out and your viscosity will be almost nothing. I encountered that with a small block Ford years ago when the diaphram in the fuel pump ruptured and filled the pan with gasoline.
Page 3 of 3 1 2 3
