Re: Nor Cal Track Night in the 340 Dart
[Re: norcal-fjo]
#2303700
05/13/17 02:58 AM
05/13/17 02:58 AM
Posts: 43,095 Bend,OR USA
Cab_Burge
Where is that track? I was under the impression that Sears point, Infineon, was the only sport car track in northern and central ,CA
[Re: Cab_Burge]
#2303702
05/13/17 03:06 AM
05/13/17 03:06 AM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
Where is that track? I was under the impression that Sears point, Infineon, was the only sport car track in northern and central ,CA Willows Ca. Awesome track. The 5 mile arrangement is amazing
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
[Re: norcal-fjo]
#2333508
07/08/17 11:02 AM
07/08/17 11:02 AM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Very cool, looks like a good and fast track - thanks for sharing - a couple questions for you...
- The rapid knocking sound in hard left corners (listen at the 1:14, 2:24, and 3:15 marks, the last turn before the straight) - what is that coming from? - What rims are you using? Cheers, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: norcal-fjo]
#2338151
07/17/17 01:21 AM
07/17/17 01:21 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
You can ditch the rear links for heims, way more compact and work better to.
Mopar to the bone!!!
[Re: norcal-fjo]
#2338170
07/17/17 01:59 AM
07/17/17 01:59 AM
Posts: 22,695 Bitopia
jcc
Bitopia
Is that night in Ca? Your tires were "talking" with authority , you looked smooth
