Re: Stupid ? Is it even possible to put the z bar on wrong?
[Re: toplescuda]
#2306933
05/18/17 07:03 PM
05/18/17 07:03 PM
Posts: 25,726 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If I shoved the clutch in and released it. The pedal would look normal I guiess. But I can grab it with my hand and pull a inch or so and feel the pedal go over center Then you have too much free play in the pedal. Forget about the free play measurement at the pedal and set it at the fork like the book says.
[Re: toplescuda]
#2307043
05/18/17 10:21 PM
05/18/17 10:21 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
You need to adjust the clutch with the pedal all the way up. The over center spring should hold it there. Then adjust the clutch linkage so the bearing has no more than a half inch movement before it contacts the forks. Then when you push on the pedal it should only move an inch or two before you can feel the bearing engage the forks and release the clutch. That's a good starting point for final adjustment once the car is running.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: toplescuda]
#2307544
05/19/17 07:42 PM
05/19/17 07:42 PM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Climbed back under the car... If..... ya shove clutch pedal down. And release. The throw out bearing rest on the fingers of pressure plate If I grab the pedal by hand and pull it up 2 inches or so. Until it rest on the bump stop. Then it does not. For the life of me I can't fig out why the pedal does not fully come up
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#2307554
05/19/17 07:55 PM
05/19/17 07:55 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I took 7 pics of it the setup
[Re: toplescuda]
#2307567
05/19/17 08:17 PM
05/19/17 08:17 PM
Centerline
Texas Hill Country
I took another look at your pics and it looks like the "Z" bar may be binding in this pic. The nut on the right looks off plane to me. Also, take a close look and make sure its not rubbing on the exhaust header. It looks awful close in the pic.
[Re: toplescuda]
#2307572
05/19/17 08:23 PM
05/19/17 08:23 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
It's not in bind anywhere. Before I put the rod from. Z bar/clutch fork. On The assembly moved very easy by hand
[Re: toplescuda]
#2307624
05/19/17 09:44 PM
05/19/17 09:44 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I just posted them on facebook
[Re: toplescuda]
#2307627
05/19/17 09:52 PM
05/19/17 09:52 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Thank you. I sent them to your email
[Re: toplescuda]
#2307646
05/19/17 10:33 PM
05/19/17 10:33 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
It seams that there is a hole on the z bar and that is where I put the spring. Was told it should connect to the bellhousing. So I went to the shop and moved it to the bellhousing. But it didn't help any Stanton. Thank you I sent the new pics to your email
[Re: toplescuda]
#2307648
05/19/17 10:34 PM
05/19/17 10:34 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I can adjust the rod more towards the end but the t.o. bearing will touch all the time even if pedal is all the way up.
[Re: toplescuda]
#2307670
05/19/17 11:29 PM
05/19/17 11:29 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Update...again lol I placed the pedal so with little movement will break over on its own (in limbo) And adjusted the rod till I heard the pedal brakes over I adjusted it more while using some heavy paper between finger and t.o. bearing to make sure wasn't touching. I got it where it would come all way up on its own. But after shoving pedal down 5-6 times notice each time it got a little less closer to the top...my thoughts on this is the shoulder of the new nut working into the new washer It does make a hard thud/clunk when the pedal hits the stop. Is something missing? I know it don't do/sound like that when new lol
[Re: toplescuda]
#2307744
05/20/17 03:09 AM
05/20/17 03:09 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Maybe it's just louder cause there is no int.in the car
