Re: Perfect match
[Re: Old School]
#2273315
03/20/17 10:24 PM
03/20/17 10:24 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
Getting a little bit closer!!
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Perfect match
[Re: Cab_Burge]
#2273328
03/20/17 10:44 PM
03/20/17 10:44 PM
Old School
Virginia Beach, VA
It looks like the exhaust pipes are going to be fun to make Good luck I have a guy that is looking forward to it. Really with the coil over suspension, I looks like there is a lot of room....
Re: Perfect match
[Re: Old School]
#2273468
03/21/17 02:03 AM
03/21/17 02:03 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I know all about very little room... and this side has all the room(I had to move the engine 1" to the right)
Re: Perfect match
[Re: twayne24365]
#2273532
03/21/17 10:00 AM
03/21/17 10:00 AM
Posts: 243 Cranberry Twp PA (North of Pit...
rumblefish72
how do you like the QuickTime bell? I have one for my big block dart and was wondering if there are any problems as far as the fitment an linkage set up? If someone starts another thread on the Quicktime Bell housing, I'll post my experience converting from a Lakewood to a Quicktime in my 'Cuda. I documented the whole process and have pictures and weights. I ran into all of the problems mentioned so far and a few extra ones for good measure. The thought of shaving a few pounds hooked me but it was a headache to convert and I'm still chasing down the last issues (I hope).
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Perfect match
[Re: rumblefish72]
#2273545
03/21/17 10:33 AM
03/21/17 10:33 AM
Old School
Virginia Beach, VA
how do you like the QuickTime bell? I have one for my big block dart and was wondering if there are any problems as far as the fitment an linkage set up? If someone starts another thread on the Quicktime Bell housing, I'll post my experience converting from a Lakewood to a Quicktime in my 'Cuda. I documented the whole process and have pictures and weights. I ran into all of the problems mentioned so far and a few extra ones for good measure. The thought of shaving a few pounds hooked me but it was a headache to convert and I'm still chasing down the last issues (I hope). rumblefish72 l would love to hear about your experience with the quicktime bellhousing. I could add my experience to it too...
Re: Perfect match
[Re: Old School]
#2274336
03/22/17 04:56 PM
03/22/17 04:56 PM
Old School
Virginia Beach, VA
Everything is fitting nice. Even around the z-bar clutch linkage. Ton of Room for headers! Recap: 588" 950 HP 860 TQ hoping for round 3000 pounds....
Re: Perfect match
[Re: Old School]
#2295813
04/28/17 10:30 PM
04/28/17 10:30 PM
Old School
Virginia Beach, VA
This is the tight passenger side done. Look at all that room around the spark plugs! I will have better plug access with this car, then any of my B bodies or E bodies
Re: Perfect match
[Re: Old School]
#2295905
04/29/17 01:25 AM
04/29/17 01:25 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I don't know if it is just the pictures, but I don't like the tube angle going into the exhaust flanges. I understand that it is a tight fit, but it seems to be creating a very tight angle.
[image][/image]
Re: Perfect match
[Re: sgcuda]
#2295956
04/29/17 09:45 AM
04/29/17 09:45 AM
Old School
Virginia Beach, VA
It is a little bit of a tight angle. I don't see any other way to get that large of a tube or the spark plug Clearence and drop down under the chassis. It is definitely a compromise with this tight engine bay, kind of like a low Port EZ head is. It still is a good size tube...
