46re 2WD pcm in 4wd
#2295851
04/28/17 11:38 PM
04/28/17 11:38 PM
Posts: 619 nj
JAMESDART
nj
I put a 2000 5.9 and 46re in my tj. I had pcm issues so I bought another used one, which had different issues. I then picked up a MP pcm for 2WD Dakota r/t. All of the other issues are gone but I didn't realize the 2WD pcm would be a problem. So What is going to happen when I put it in 4low? Can a tuner switch it to 4wd?
Re: 2WD pcm in 4wd
[Re: JAMESDART]
#2296054
04/29/17 01:05 PM
04/29/17 01:05 PM
Posts: 5,999 Salem
Grizzly
Moparts Proctologist
Salem
This is deep. So, my '01 360/46re, when you put it in 4lo and step on it, it will "stumble". It only does this in 4lo, yet there is no connection to the pcm that the truck is in low range that I can see. The "stumble" must be an early form of torque management so you don't twist something apart. Maybe there is a wire going to the transfer case to tell the pcm it's in low? Don't waste your time or money on them b.s. "tuners". I'd get a computer out of a 4wd Ram if I was you: Cost you less than a tuner in dollars and aggravation.
Mo' Farts
Moderated by "tbagger".
Re: 2WD pcm in 4wd
[Re: JAMESDART]
#2296317
04/30/17 12:10 AM
04/30/17 12:10 AM
Posts: 619 nj
JAMESDART
nj
I did get a pcm from a ram, and it was bad. Honestly after the 3rd pcm I did feel like buying any more. I'm pretty sure There is a transfer case range input on the pcm for the 46re trans.
Re: 2WD pcm in 4wd
[Re: JAMESDART]
#2296495
04/30/17 01:31 PM
04/30/17 01:31 PM
Posts: 5,999 Salem
Grizzly
Salem
Ok, were the PCM's the same year as everything else? How is this running your gauges and such on the TJ?
Mo' Farts
Re: 46re 2WD pcm in 4wd
[Re: JAMESDART]
#2296645
04/30/17 05:56 PM
04/30/17 05:56 PM
Posts: 619 nj
JAMESDART
nj
Everything works 100% Tj is a 98 Durango donor was a 2000, that had an issue where it would run 20-30 min and would die and not restart, I believe that was the " no bus" problem. It actually did that in the Durango before I pulled it apart. I forget the truck pcm maybe 99. It had a code for the rear o2 sensor and if I watched live data while it was running, it was not reading the sensor. It wasn't the sensor and it wasn't my wiring. So I decided to try another pcm, which is the molar performance 2000 Dakota r/t pcm. I am not against having a custom tune done from someone like flyinryan, but I need a good pcm.
So back to my original question, what is going to happen when I put it in 4 low? With a 2WD pcm? Does anyone know? And can I have my 2WD pcm tuned to a 4wd?
[Re: JAMESDART]
#2297063
05/01/17 12:10 PM
05/01/17 12:10 PM
Posts: 5,999 Salem
Grizzly
Salem
You are using mis-matched, and corrupted pcms. Can't help you. Call "flynryan" and ask him.
Mo' Farts
[Re: JAMESDART]
#2297081
05/01/17 12:46 PM
05/01/17 12:46 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
Put it in 4 low and let us know ... as far as tuning it , Dodge software is propitiatory so I don't know if anyone has been able to break into one that old and retune it. We are still waiting for someone to come out with a standalone to run an RE trans as far as I know.
[Re: JAMESDART]
#2297747
05/02/17 02:38 PM
05/02/17 02:38 PM
dogdays
If I was designing the computer I'd put the speedometer sensor at the output of the transfer case. Then there is no need to shift or switch anything when going into Low range.
I'd be surprised if it is more complicated than that.
In later model years, with torque management more on the engineers' minds, there may have been some input to the computer.
R.
