Re: tie rod ends
[Re: 69fish]
#2295112
04/27/17 04:28 PM
04/27/17 04:28 PM
Posts: 892 MA
steve70
MA
I would check on Rock Auto's website. It should be in the description of the part
1970 Challenger T/A 4 speed
Re: tie rod ends
[Re: 69fish]
#2295694
04/28/17 05:13 PM
04/28/17 05:13 PM
RapidRobert
As you know you just need a rightie and a leftie on the dr side and a rightie and a leftie on the pass side & you can turn the sleeve so as to have a rightie or leftie either way. they totally interchange (exc for the obvious LHT tie rod goes in the LHT end of the sleeve) & likely the OE order that SuperCuda said was how they were laid out on the assembly line for the easiest/fastest/automatic no thinking required assembly. Maintaining the OE order (at least in this case) is the good plan. If they ain't marked, left hand threads have an unmistakeable weird angle twist that you cant miss.
Re: tie rod ends
[Re: RapidRobert]
#2295848
04/28/17 11:35 PM
04/28/17 11:35 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
As you know you just need a rightie and a leftie on the dr side and a rightie and a leftie on the pass side & you can turn the sleeve so as to have a rightie or leftie either way. they totally interchange (exc for the obvious LHT tie rod goes in the LHT end of the sleeve) & likely the OE order that SuperCuda said was how they were laid out on the assembly line for the easiest/fastest/automatic no thinking required assembly. Maintaining the OE order (at least in this case) is the good plan. If they ain't marked, left hand threads have an unmistakeable weird angle twist that you cant miss. Yes but you mess up the alignment guy if you do it backwards
Re: tie rod ends
[Re: Morty426]
#2296074
04/29/17 01:36 PM
04/29/17 01:36 PM
RapidRobert
Yeah I can see where if he assumed that it still was OE that he would turn the sleeve the wrong way & be moving the toe in in the opposite direction of what he wants for a minute till he saw what was happening which would slow his final completion of the alignment. I always look for which end of the sleeve that the oddball LH threads are at then turn the sleeve accordingly.
