Re: 727 & 2-3 shift flare
[Re: Colin Frolick]
#229503
02/19/09 04:14 AM
02/19/09 04:14 AM
Posts: 2,273 Bern, Switzerland
6o4o
Bern, Switzerland
I asked on the lever ratio because of the turns! You should be able to see the ratio when you remove the pan. Depending on the ratio you have to adjust the front band. I don't think it will change the flare problem but it's always good to know the ratio and like that the band adjustments. The biggest hole you can make is to remove the orifice as original! But then you will probably have to much overlap causing the 2-3 shift to feel hard and maybe noisy ("clonk" sound). Best to see this if you lift up the rear end in the air and start to accelerate and look at the wheels when the 2-3 shift comes. If they slow down a lot or even stop you got too much overlap. I would guess you just need to increase the size of the orifice hole. Too much and it will start to have more overlap that makes you loose ET and also is hard on the transmission…
[Re: 6o4o]
#229508
02/19/09 11:56 AM
02/19/09 11:56 AM
Posts: 236 Southern CA
Colin Frolick
Southern CA
it has the stock governor weight. i adjusted the line pressure screw about "2 turns in from just flush" per the transgo instructions. the kickdown setup is the original equipment 1-piece rod. a difference is I put a thermoquad on the motor (an AVS was original) and the TQ must have the throttle shafts or at least the linkage is further forward, so to be able to get the kickdown rod all the way back at WOT i stuck a bolt in this slot (see pic) to shorten it, otherwise i was out of travel on the regular adjustment. if yall have ideas on that i'd welcome them. when you do the tf-2 kit and grind the throttle valve shorter you have to readjust the rod back somehow correct? i don't know about the servo springs, i'll check that and the pin clearance, thanks for the suggestions. the motor seems to pull well to 6000. the cam is 231/237 @0.050, 112 lsa, 0.560" lift with 1.6 rockers. e-heads, headers etc. although 5500 would probably be adequate
[Re: Colin Frolick]
#229512
02/19/09 07:24 PM
02/19/09 07:24 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Instead of slowly increasing the orifice size try it with the orifice plug removed.
[Re: John_Kunkel]
#229513
02/28/09 01:46 AM
02/28/09 01:46 AM
Colin Frolick
Southern CA
so the latest is, i'm losing 2nd gear. when it kicks down to 2nd it sliiiiips then goes, i'm backing off cause i feel it slipping. it used to be brutal. and i barely feel the 1-2 upshift it's gotten so soft. could i have wrecked a new red-lined front flex band already? maybe the flaring i was noticing on the upshift was the band starting to slip too soon? it chirped the tires the other day shifting to 3rd, so the front clutch must be applying ok. are flex bands garbage? the original piece was a solid band. i'm thinking i should have gotten one of those. i may be making 600 lb/ft? and this imp weighs close to 5000# ? any other upgrades should i think about for this trans at this point... higher ratio lever, better servos, more clutch springs... etc. looks like i'm taking it apart again. Cheers
