2000 Sebring JXI convertible brake bleeding #2294892
04/27/17 09:50 AM
04/27/17 09:50 AM
Manheim PA.
mopardad Offline OP
mopardad  Offline OP
Manheim PA.
anyone know the proper order to bleed brakes on this, had the right front brake hose apart at the joint between the steel line & rubber hose & installed new front pads. Brake pedal now is spongy & goes to floor, tried bleeding RR, LR, LF, RF, don't seem to be getting any air out. Does the ABS need bled ? If so can it be done without a scan tool? Thanks
Re: 2000 Sebring JXI convertible brake bleeding [Re: mopardad] #2295976
04/29/17 10:44 AM
04/29/17 10:44 AM
NJ
rth Offline
rth  Offline
NJ
RF before LF. Start further from master and work towards it.
