Re: Valve cover spray bars
[Re: 408strokerdart]
#2294869
04/27/17 07:54 AM
04/27/17 07:54 AM
Posts: 2,915 A shed in England
Tig
A shed in England
Hi guys. Just wondering what size holes most are using in their oil spray bars? I will be using straight 40 weight oil. I also assume they really drip more than spray (which is all they really need to do). The spray bars from Indy come with pretty large holes and seem like they would flood the top of the engine with oil. I would rather keep more oil where it belongs if possible. Anyone done any experimenting with this? The spray bars from Indy usually come with a restrictor in the fitting that goes into the valve cover. It's normally a drilled out grub screw. It is more of a drip, as you state and we've run them on the 528, 572 and 655 with no issues. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: greendart408]
#2295122
04/27/17 04:37 PM
04/27/17 04:37 PM
Posts: 3,456 Out West
408strokerdart
Out West
I can pin guage my w8 covers for you tomorrow am, the rails are gun drilled, I'm thinking they are .010 to .015 without measuring them. That would be helpful. Thanks.
[Re: Tig]
#2295125
04/27/17 04:38 PM
04/27/17 04:38 PM
408strokerdart
Out West
Hi guys. Just wondering what size holes most are using in their oil spray bars? I will be using straight 40 weight oil. I also assume they really drip more than spray (which is all they really need to do). The spray bars from Indy come with pretty large holes and seem like they would flood the top of the engine with oil. I would rather keep more oil where it belongs if possible. Anyone done any experimenting with this? The spray bars from Indy usually come with a restrictor in the fitting that goes into the valve cover. It's normally a drilled out grub screw. It is more of a drip, as you state and we've run them on the 528, 572 and 655 with no issues. HTH's Do you have any pictures of the "restrictor" that Indy uses? I have a set of their covers and there is no restrictor or provision for one present. Maybe my covers were converted to spray bar by someone else...
#2295178
04/27/17 06:45 PM
04/27/17 06:45 PM
Tig
A shed in England
It might be a little difficult to photograph, the - 4AN T piece, that's fitted to the valve cover, is tapped to accept a drilled out grub screw. I'll try to photograph one tomorrow, there is a spare set on one of the shelves
#2297706
05/02/17 01:14 PM
05/02/17 01:14 PM
Posts: 4,206 New York
polyspheric
New York
I agree with Stanton - the smaller hole at the spray gives the best effect, and the overall delivery rate should be controlled by a restrictor in the feed line to the cover: highest pressure in the small lines. However: long history in motorcycle engines says that even an .020" hole will eventually clog with debris, shredded gasket, dust, etc. The hole must be larger if you never service/inspect it, like .030". A filter in the big line may cure this and allow smaller holes, but it's got to be pretty fine to help. I have a feeling that the hole edge should remain sharp to disrupt the flow (rather than radiused or counter-bored).
Boffin Emeritus
