Page 14 of 20 1 2 12 13 14 15 16 19 20
Re: Moparts official power adder thread [Re: FastmOp] #2291492
04/21/17 11:48 AM
04/21/17 11:48 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Originally Posted By FastmOp
The exhaust wheel and housing needs to be the biggest you can get. I run a 106mm turbo on an Indy -1 motor.
This power adder section should be named after Monte
You are so right! Thanks to the powers that be!
Race in Piece Monty!
http://www.hotrod.com/articles/nitrous-innovator-monte-smith-passed-away/
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Moparts official power adder thread [Re: tboomer] #2291679
04/21/17 05:48 PM
04/21/17 05:48 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
If anyone wants to share some Monte nitrous tunes, post em up. Like jet sizes and such. I never messed with it much but now wish I had one of his setups for my Valiant.
Re: Moparts official power adder thread [Re: FastmOp] #2291692
04/21/17 06:06 PM
04/21/17 06:06 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
The purpose of Monte or any of the nitrous companies was/is their knowledge of cylinder heads, compression ratio, camshaft profiles, etc. which dictate jet mapping, fuel pressure and timing. There is no one size fits all.
Monte had done my work for many years and I will miss him!!!
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Moparts official power adder thread [Re: tboomer] #2293147
04/24/17 11:19 AM
04/24/17 11:19 AM
an8sec70cuda Offline
When wiring a progressive, which wires are the main ones to be concerned w/ as far as interference?...the grounds to the solenoids? The 12v activation?
I've always heard the Edelbrock controllers are REALLY sensitive to interference, but work great. I'm just using an older 2 dial controller for now, but really like the Leash products I've used in the past (on other people's cars) and will most likely end up getting one of their controllers when funds allow.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Moparts official power adder thread [Re: n20mstr] #2293325
04/24/17 05:54 PM
04/24/17 05:54 PM
NC
O
onefastindy Offline
onefastindy  Offline
O
NC
Yes it is... that wasn't suppose to have happened
Re: Moparts official power adder thread [Re: FastmOp] #2293458
04/24/17 09:26 PM
04/24/17 09:26 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Induction Solutions has recommended jetting. It's a start. Much better than the old nos jetting. I end up taking fuel jet out from there.
I can't preach take plenty of timing out to be safe enough. If you are not detonating its harder to hurt it. Rich tunes are not safer tunes. It's nearly impossible to hurt something running too lean. Ever blow your racing dirt bike up running out of gas? Didn't think so. Now if you are detonating like crazy and stuff is about to melt, well you might hurt it. But, lack of fuel didn't do this. Detonation got it.
On new stuff start with a really lean hit. Run engine timing as low as possible and with a nice lean tune in carb. Pull plenty of timing. 2 per 50hp and some extra. Another 4 if you have a small quench.
To tune from here. Trim fuel pressure to see if you pick up mph. If not put it back. Take another degree of timing out. If it don't pick up put it back.
Add a degree of timing, try again. Key thing if the mph quits picking up put it back. New plugs pushed in the lanes and cut off at end of pass will give you the best reading. Plenty of this info on Induction solutions website. I run a little leaner than they recommend but great place to start.
Re: Moparts official power adder thread [Re: tboomer] #2293635
04/25/17 02:01 AM
04/25/17 02:01 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
What would be a good starting point jetting for a fogger with E85? Looking for 28 jets for the nitrous, but what size fuel?
Plynouth VIP '67 TT IC EFI
Re: Moparts official power adder thread [Re: jyrki] #2293872
04/25/17 02:41 PM
04/25/17 02:41 PM
NY
challenger451ci Offline
NY
With Induction Solutions help, I ended up at 0.030n and 0.028f jet on E85, 925psi Nitrous pressure. Fuel is usually around 5.75-6.25psi flowing depending on the air. We get some big weather changes here in update NY between daytime in July the cold November nights. I agree with Leon, start conservative with timing and fuel, tow up and back to get a good plug reading. My hoagie seems to like around 20deg in a 12:1 528ci, flat tops with Indy SR heads for reference.
Re: Moparts official power adder thread [Re: tboomer] #2298638
05/04/17 01:03 AM
05/04/17 01:03 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Best tuneup that worked for me...
Plate 70n 60f 5.0 fuel flowing
Direct port .036n .026f 4.5 flowing
Timing with it all on.... 8*
Reason for the low timing was the cam was not that nitrous friendly.
The real tuneup is give the motor what it wants, the right amount of fuel and timing. You need to be able to tell what it wants. Too much timing always hurts parts. So always retard it first, if adding timing doesn't pick up mph....you went the wrong way !
Baby steps
....BAD A$$ STREET CAR.....
Re: Moparts official power adder thread [Re: challenger451ci] #2298640
05/04/17 01:04 AM
05/04/17 01:04 AM
N
n20mstr Offline
n20mstr  Offline
N
How fast has it gone ?
Lol
Re: Moparts official power adder thread [Re: n20mstr] #2299319
05/05/17 01:32 AM
05/05/17 01:32 AM
NY
NY
Lol
Not even remotely fast in your world! 3500lb streeter that sees mostly "highway" time. Was that 0.036 tune you mentioned above on E85 or gas? That sounds CLEAN for the corn!
Re: Moparts official power adder thread [Re: challenger451ci] #2299744
05/05/17 09:19 PM
05/05/17 09:19 PM
N
n20mstr Offline
n20mstr  Offline
N
Yes race gas.
And it was 440-1 heads, small .680 roller, street able.
Went 5.30's at 132 @ 3350lbs
Re: Moparts official power adder thread [Re: n20mstr] #2300021
05/06/17 12:01 PM
05/06/17 12:01 PM
NY
NY
That's makin time! I'm hoping for .50's this year with my barge. I think it's gonna need a little more jet depending how early I can get it all in.
Re: Moparts official power adder thread [Re: an8sec70cuda] #2300156
05/06/17 03:26 PM
05/06/17 03:26 PM
Granbury TX
Prochargedmopar Offline
Granbury TX
If this thread was given it's own forum traffic would most likely pick up.
Not being able to post "new" topics to search by is a little gitchy.
Replying in one loooong thread there is no way to tell what topics are covered without reading the whole thing.
jmo
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: Moparts official power adder thread [Re: tboomer] #2300174
05/06/17 03:52 PM
05/06/17 03:52 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Monte Smith's MoPower Adder forum.
Re: Moparts official power adder thread [Re: FastmOp] #2300676
05/07/17 01:31 PM
05/07/17 01:31 PM
hemi-itis Offline
hemi-itis  Offline
So much knowledge,lost way too many in the last few years.Still having a hard time dealing with it,,,,,,,,, frown
Re: Moparts official power adder thread [Re: tboomer] #2300804
05/07/17 07:06 PM
05/07/17 07:06 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
Would love to get a sticker like that.
Re: Moparts official power adder thread [Re: one bad fish] #2300933
05/07/17 11:39 PM
05/07/17 11:39 PM
N
n20mstr Offline
n20mstr  Offline
N
Why ? You don't use a power adder
Re: Moparts official power adder thread [Re: challenger451ci] #2300937
05/07/17 11:42 PM
05/07/17 11:42 PM
N
n20mstr Offline
n20mstr  Offline
N
Here is a Monte trick, hit it as hard as you can for the first two tenths, then pull your launch timing out. Monte said, everything dead hooks for two tenths...
Re: Moparts official power adder thread [Re: n20mstr] #2301303
05/08/17 07:09 PM
05/08/17 07:09 PM
Rogue River, OR
Jeremiah Online work
Jeremiah  Online Work
Rogue River, OR
Good stuff, keep it coming!
RIP buddy!
