Re: what oil are you running in your street big block?
[Re: Pacnorthcuda]
#229360
02/21/09 11:38 AM
02/21/09 11:38 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I used to run Chevron Delo CI, but I agree with Doug's concerns about high detergent levels. I have gone back to passenger car oils (currently just Castrol 10w-30) but with a bottle of ZDDPlus.
I think its risky to assume the zinc levels are REALLY in the oil in question. Formulae change--even when the designation (CI/CJ, SL/SM) may not. However, Amsoil/Redline/BradPenn/Royal Purple are probably excellent,safe, choices because they cater to our niche market, I just prefer to dump the additive in myself.
BTW, I posted two staveley analysis of Chevron Delo 400 LE 15w-40 (thats the CJ-4 formulation) last summer. The Zn numbers were between 1275 and 1300ppm.
Greg,were those samples new our used oil.I have noticed that our used oil (between 18/20k miles) have a higher zinc content than new.I assume some of that zinc is from engine wear.We run the same oil in 50+ Dt466's and a 8 road tractiors with NP400 Cummins.
[Re: 62maxwgn]
#229362
02/21/09 12:04 PM
02/21/09 12:04 PM
Posts: 21,808 Kirkland, Washington
Pacnorthcuda
These were new samples, pulled directly from our 2000 gallon tank and the dispensing gun (nozzle) in the plant. Not from a crankcase. I was guessing the levels would be more like 1100ppm (considering it was LE CJ-4) and was surprised at the results. I still feel more confident adding my own additive though!!
[Re: 62maxwgn]
#229363
02/22/09 11:32 PM
02/22/09 11:32 PM
Posts: 1,019 Eau Claire, WI
ResQ911
super gas
super gas
Eau Claire, WI
years ago kendall was the hot ticket recomended to me by several racers and such(str8 40 for my application). From what I gather they were bought out and no longer run the formula that everyone was after. I have searched out other alternatives and found BradPenn oil. I think its the good stuff everyone was after. Check out their web site. http://www.bradpennracing.com/
Brad Penn is coming from the old Kerndall refinery in Bradford,PA.And the analysis I had done on Brad Penn Grade 1 20/50 racing oil.Sure beats guessing and heresay,lets see some of the others.
Penn Grade 10W30 in my flat tappet 496 stroker.
