Another Problem #2292650
04/23/17 12:32 PM
04/23/17 12:32 PM
MR_P_BODY Offline OP
I was trying to add another pin in the main
plug harness yesterday.. but I couldnt get the
plug to release.. I called Rick(Trendz) to see
if I was doing something wrong and I talked to
Holley(on the web)and no one knows why it wont
release... since I cant release it and I managed
to break another wire during this process I'm
just gonna cut the plug off and order a new plug
with the pins.. I dont care about the price but
I do care about the time loss.. its just one thing
after another..such a simple job turns into a big
pile of worms cry... I hate playing with small wires
wave
Re: Another Problem [Re: MR_P_BODY] #2292657
04/23/17 12:47 PM
04/23/17 12:47 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I'm with you on that. It should be easy then turns into a huge hassle. Sorry it turn out that way.
Re: Another Problem [Re: MR_P_BODY] #2292665
04/23/17 12:55 PM
04/23/17 12:55 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Mr P. You pointed me to using cheater lenses while welding. That really was a big plus. Try the same thing for those little connectors. It will give you a better viewpoint of the terminal release. A torch tip cleaner tool has lots of small diameter tips that I use to release the locks. I used to build Gen3 harnesses for a 2 step launch control. Yes, all of those little pins are a pain. Sometimes I use the tool that Harbor Freight sells that has 2 alligator clips and a magnifying glass for soldering tiny components together, also.
[image][/image]
Re: Another Problem [Re: MR_P_BODY] #2292671
04/23/17 01:08 PM
04/23/17 01:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Get one of those big ass Dental lights/magnifying lenses and you will love it Mike cos w/out it, I couldn't build a single carb correctly or cleanly......... thumbs
Re: Another Problem [Re: Thumperdart] #2292688
04/23/17 01:21 PM
04/23/17 01:21 PM
For some reason it wont release.. I'm guessing
that I didnt have 1 pin pushed it all the way
when I locked it.. the release tab is big enough
to use a medium size flat blade screwdriver to
release it.. but it wont.. I'll order the part
tomorrow and WAIT.. I should be able to put the
plug on with the 20 pins in a few hours... and
yes I will buy a pair of 3.0 glasses and add more
light in there
wave
Re: Another Problem [Re: MR_P_BODY] #2292697
04/23/17 01:33 PM
04/23/17 01:33 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Another Problem [Re: pittsburghracer] #2292705
04/23/17 01:46 PM
04/23/17 01:46 PM
The biggest problem is that I'm working inside
the car.. black carpet and not a lot of room
to swing the door open all the way.. If I didnt
have it on the hoist I would have pushed it
forward to clear the door.. it is what it is..
I have one of those lights but its over my welding
bench where I do most of my work
wave
Re: Another Problem [Re: pittsburghracer] #2292714
04/23/17 02:00 PM
04/23/17 02:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By pittsburghracer
Mine is actually from a dental shop.............
Re: Another Problem [Re: MR_P_BODY] #2292946
04/23/17 10:11 PM
04/23/17 10:11 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Boy Mike, both of our cars must have came from the same womb. Always an issue every direction i turn.
Re: Another Problem [Re: mopar dave] #2292978
04/23/17 11:25 PM
04/23/17 11:25 PM
I guess they might have.. this BIC!H is driving me crazy
with the little crap.. I expected to be on the road by now
wave
Re: Another Problem [Re: MR_P_BODY] #2292985
04/23/17 11:36 PM
04/23/17 11:36 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I see that and feel your pain. Hope your luck changes soon. Good luck Mike.
Re: Another Problem [Re: mopar dave] #2293000
04/23/17 11:53 PM
04/23/17 11:53 PM
Well I'll order the stuff I need tomorrow morning
and maybe get it by Thursday and I should be all
prepped to pit it together then... I HOPE
wave
Re: Another Problem [Re: MR_P_BODY] #2293181
04/24/17 12:44 PM
04/24/17 12:44 PM
I ordered up my parts this morning and they
should be here on Wednesday... I'll cut the plug
off today and WAIT.. all this reminds me of my
military days.. hurry up and WAIT
wave
Re: Another Problem [Re: MR_P_BODY] #2295059
04/27/17 03:25 PM
04/27/17 03:25 PM
As usual.. my new plug for the injection doesnt
fit.. I bought the full kit to replace the one
plug(there are 4 plugs in the kit with all the
pins).. 3 of the plugs in the kit are 26 pin
plugs.. each has a different locator so you cant
plug in the wrong one.. on my original plug it
has 2 locators on one side and a single locator
on the other side(in the center).. of the 3 that
came in the kit(all 26 pin ones) NONE have the
correct locators.. so I will call Holley AGAIN
and see what the deal in.. then WAIT more.. I'm
getting really PISSED OFF mad .. and to wait
for a tech is no simple job.. can be a hour or
more on the phone.. and listening to that damn
music
wave
Re: Another Problem [Re: MR_P_BODY] #2295117
04/27/17 04:30 PM
04/27/17 04:30 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
sorry to hear Mike. If it were me at this point I would file the tab or tabs off and plug it in.
Re: Another Problem [Re: MR_P_BODY] #2295140
04/27/17 05:12 PM
04/27/17 05:12 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The more I hear, the more sure I am I'll keep running carbs.
Re: Another Problem [Re: fast68plymouth] #2295143
04/27/17 05:21 PM
04/27/17 05:21 PM
Way too late for that.. about $2500 to late
EDIT
I expected this to be fairly simple to change over
but its a pile of worms with little crap.. now that
Holley says they dont sell that plug I have to go
to the manufacturer for the plug and pins.. and the
manufacturer only sells the pins in lots of 100 or
more.. so I have to buy a 100.. its all the nickle
and dime crap that SUCKS and the WAITING... maybe
by next year I'll get this piece of crap running
wave
Re: Another Problem [Re: MR_P_BODY] #2295309
04/27/17 10:31 PM
04/27/17 10:31 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Look on eBay for the connectors. I have had good luck there buying connectors and stuff.
I am starting to be glad that I had to terminate my own harness. It was a little nerve racking starting out with 12' of unterminated harness but i feel it worked out better in the end. I had to source any connector I used therefore I know where to get it all. It didn't feel worth it at the time but Mike is helping that lol.
68 Barracuda Formula S 340
Re: Another Problem [Re: Bad340fish] #2297051
05/01/17 12:03 PM
05/01/17 12:03 PM
Well my new plug and pins should be in tomorrow so
I should be able to finish that up... this waiting
is killing me
wave
Re: Another Problem [Re: MR_P_BODY] #2297113
05/01/17 01:38 PM
05/01/17 01:38 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Originally Posted By MR_P_BODY
[quote=fast68plymouth]The more I hear, the more sure I am I'll keep running carbs.
EDIT
wave
[/quote
Mike got a pic of the pin you need? Are they based off a GM pin. ?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
