Re: 70 E-Body Front Strut Roll-Pin Installation
[Re: Stanton]
#2292928
04/23/17 09:40 PM
04/23/17 09:40 PM
Posts: 1,565 tennessee
pushbutton
tennessee
. Some people just have more money than brains. [/quote]
Some people don't realize that you can find stuff locally. I know I've been guilty in the past.
[Re: B5Cuda440-6]
#2293566
04/24/17 11:50 PM
04/24/17 11:50 PM
Posts: 1,057 Dallas, Texas
FC7cuda
Dallas, Texas
Rob,
I will be facing this same issue soon. I have some loose strut rods and can take one plus a used pin and see if the hardware/industrial store suggestions are valid.
68 Charger 70 Cuda
[Re: B5Cuda440-6]
#2293754
04/25/17 11:23 AM
04/25/17 11:23 AM
Posts: 892 MA
steve70
MA
Measure the hole to get the correct roll pin diameter. A 1/8 diameter hole requires a 1/8 roll pin. A 1/8 roll pin will be slightly larger and get "squeezed" as it gets pressed into the hole preventing it from falling out.
1970 Challenger T/A 4 speed
[Re: steve70]
#2293916
04/25/17 03:37 PM
04/25/17 03:37 PM
Posts: 381 Ottawa, Ontario
L.R Helbling
Ottawa, Ontario
Measure the hole to get the correct roll pin diameter. A 1/8 diameter hole requires a 1/8 roll pin. A 1/8 roll pin will be slightly larger and get "squeezed" as it gets pressed into the hole preventing it from falling out. What I did to compress the roll pin into the hole of the strut was put it into a set of small vice grips and then ease it into the hole. Once in the hole you can drift it in using a small punch.
