Re: help calculate my comp using 1/2"downfill method
[Re: KOS]
#2291618
04/21/17 03:34 PM
04/21/17 03:34 PM
Posts: 4,457 Washington
madscientist
Washington
The method in th Chrysler book is the easiest way to do downfill compression ratio calculation.
It gets a bit tricky when the deck of the piston is positive. If you are using a zero or negative deck, it's pretty straight forward.
[Re: KOS]
#2291647
04/21/17 04:29 PM
04/21/17 04:29 PM
Posts: 43 California USA
LowDeck451
California USA
well had a buddy run it through his program and came up with 14.6 Hmm...Well, I could be wrong, but I don't see where. Interesting that we are 1 full point apart.
[Re: LowDeck451]
#2291660
04/21/17 05:09 PM
04/21/17 05:09 PM
KOS
Do you know your gasket bore dia.? Also, it looks like your 129cc downfill puts your deck height at 1cc 'positive'. A 4.5" cyl., .5" deep calcs out to 130cc. I subtracted 1cc from chamber volume, took a guess at your gasket bore dia. at 4.6", and the compression calculator said 13.66 to 1. I'm pretty sure this is correct, but it does get confusing at times! Hope this helps. gasket bore we used was 4.560 we tried different bore sizes not much diff.....wow 13.66 thought it woulda been more.thx for the input
[Re: KOS]
#2292026
04/22/17 11:57 AM
04/22/17 11:57 AM
Posts: 4,205 New York
polyspheric
New York
The .500 method isn't magic, as Cab_Burge says whatever depth is needed to cover the dome. .500" is just to make the math easy, you could use .391" down.
Boffin Emeritus
[Re: KOS]
#2292057
04/22/17 12:58 PM
04/22/17 12:58 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
1205 swept 76 chamber 19.8 gasket -1.3 dome vol -6.5 deck ---------- 1293 total 88 total minus swept ---------- 14.69 (1293/88)
[Re: B1MAXX]
#2292097
04/22/17 02:06 PM
04/22/17 02:06 PM
LowDeck451
California USA
guys I need to understand this when I saw fast's reply I became confused....believe me all this was meant in a positive light and meant to learn from.
Here is the way I have done this...please point the error of my ways. 1/2 bore times itself 2.25x2.25=5.06 times pie 5.06x3.14=15.89 times stroke 15.89x4.625=73.52 time ci to cc factor 73.52x16.387=1204.77 I rounded this to 1205cc
add head cc 1205+76=1281 add gasket cc... use same formula as above but used4.56 for bore and .074 for thickness times ci to cc factor 1.20x16.387=19.66 I rounded this to 20cc 1281+20=1301 add or subtract deck vol which in this case is -1 based on a -.500 perfect deck vol. of 130cc used same as above but used 4.5 for bore and used .500 for thickness
1301-1+1300 total vol at bdc 1300
ok vol at tdc would be 76cc+20cc-1cc=95cc
1300/95=13.68
Me too.????
[Re: fast68plymouth]
#2292099
04/22/17 02:11 PM
04/22/17 02:11 PM
LowDeck451
California USA
1205 swept 76 chamber 19.8 gasket -1.3 dome vol -6.5 deck ---------- 1293 total 88 total minus swept ---------- 14.69 (1293/88) I guess I'm not understanding the '-6.5 deck' in your calc. Thanks.
