Page 1 of 3 1 2 3
Pro Touring Twin Turbo 73 Cuda #2291399
04/21/17 02:05 AM
04/21/17 02:05 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Figured I would post up the build of my Cuda. If anyone has questions let me know.
It started off as a 73 340 4spd Cuda. Originally silver/gray color with one repaint. The engine was a 69 340 with some old school mods. The trans was not in the car when I bought it and did not run. Put a new clutch and carb on once back home and got a chance to drive. The rear tires rubbed on any bump and the oil pan was missing the rear seal so there was a very bad oil leak shruggy.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2291402
04/21/17 02:07 AM
04/21/17 02:07 AM
California
slowfab Offline OP
slowfab  Offline OP
California
I patched up the oil pan and then ordered some new wheels. This got the car in driving condition. This lasted about 3 months.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2291408
04/21/17 02:15 AM
04/21/17 02:15 AM
California
slowfab Offline OP
slowfab  Offline OP
California
It was about time to tear down for the build. No real surprises luckly.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2291411
04/21/17 02:22 AM
04/21/17 02:22 AM
California
slowfab Offline OP
slowfab  Offline OP
California
The car was stripped down to the bare body and paint stripped. Added the US Car tool frame connectors, torque boxes and inner fender supports. At this time I had settled on the game plan to go with turbos. Instead of the normal intercooler in front of the radiator I decided to put one on each side. This required narrowing up the valance opening for the radiator. I brought it in to match the radiator opening. Then added the 2 holes for each intercooler.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2291412
04/21/17 02:25 AM
04/21/17 02:25 AM
California
slowfab Offline OP
slowfab  Offline OP
California
At the paint shop.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2291414
04/21/17 02:39 AM
04/21/17 02:39 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Out of paint.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2291557
04/21/17 01:59 PM
04/21/17 01:59 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Very nice looking project. Keep us updated!!
Re: Pro Touring Twin Turbo 73 Cuda [Re: killermopar] #2291601
04/21/17 03:07 PM
04/21/17 03:07 PM
Oakville, Ontario, Canada
CDN72SE Online content
CDN72SE  Online Content
Nice!
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2291645
04/21/17 04:23 PM
04/21/17 04:23 PM
Chicago
rocksmopar Offline
rocksmopar  Offline
Chicago
Small block with the turbos?
Body looks perfect, can't wait to see how you route everything...
Looking for affordable 72-74 Cuda parts
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2291920
04/22/17 01:42 AM
04/22/17 01:42 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Building the ducting for the intercoolers.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2291932
04/22/17 02:05 AM
04/22/17 02:05 AM
California
slowfab Offline OP
slowfab  Offline OP
California
With intercoolers in and setting up the A/C condenser.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2291935
04/22/17 02:15 AM
04/22/17 02:15 AM
California
slowfab Offline OP
slowfab  Offline OP
California
The engine had forged pistons already so I added some Edelbrock heads. To help drop the compression I used .110 thick Cometic mls head gaskets. The cam is from Comp spec'd for turbo use. When this started I was conservative thinking I would just go big block once this failed but once done the packaging was such a pain that would not want to start over with a BB.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2291940
04/22/17 02:18 AM
04/22/17 02:18 AM
California
slowfab Offline OP
slowfab  Offline OP
California
I took a set of SBC stainless headers and modified them to SBM flanges. The turbos are ebay T4 G35 units.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2292229
04/22/17 05:49 PM
04/22/17 05:49 PM
Maryland
K
Keepat Offline
Keepat  Offline
K
Maryland
very cool project!!
Pat
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2292411
04/22/17 11:35 PM
04/22/17 11:35 PM
California
slowfab Offline OP
slowfab  Offline OP
California
I started with a Richmond 4+1 trans but it started leaking just sitting in the can and never being driven. When I contacted Summit/Richmond they said it would be about 2 months before they would get the same one back in stock or make one. So I returned and put a TKO600 in it. Went with a twin disk clutch.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2292903
04/23/17 08:20 PM
04/23/17 08:20 PM
California
slowfab Offline OP
slowfab  Offline OP
California
The headers with the new flanges and set for the application.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2292904
04/23/17 08:23 PM
04/23/17 08:23 PM
California
slowfab Offline OP
slowfab  Offline OP
California
The rearend is a 8.75 with 3.91 gears and a truetrac posi. Used a B-body housing the let the wheels have a little depth and offset some of the rotor hat thickness.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2292909
04/23/17 08:39 PM
04/23/17 08:39 PM
California
slowfab Offline OP
slowfab  Offline OP
California
I went with a aftermarket aluminum tank that was supposed to be "baffled" for road/track use but it still will starve for fuel on accel if bellow 1/2 tank. I went with a air ride suspension kit. I had to make new lower links to work with the 1" offset mounts of the B-body housing.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2293555
04/24/17 11:34 PM
04/24/17 11:34 PM
California
slowfab Offline OP
slowfab  Offline OP
California
IT was a rally dash car but somewhere along the line someone was using the gauges as their cigarette holder so the lens was discolored and warped. I wanted extra gauges for the boost but do not like aftermarket gauges stuck on top of the bezel. I found gauges from Speedhut that are close to the diameter of the stock gauges so I picked them up. Made custom tubes to hold the gauges and bonded them to the stock bezel.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2293558
04/24/17 11:37 PM
04/24/17 11:37 PM
California
slowfab Offline OP
slowfab  Offline OP
California
Dash in car
Page 1 of 3 1 2 3
