Page 2 of 3 < 1 2 3 >
#2294836 - 04/27/17 12:33 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
The fabrication of the turbo system was a large challenge in packaging. With OEM power steering, A/C and cutting of the car kept at a minimum. Only 2 large holes were cut in the car. That was where the tubes leave the inter coolers and run through the inner edge of the fenders and through the core support. The air leaves the turbos and exits down toward the ground and through the inlets to the intercoolers. All of that was not so bad. The exhaust and waste gate plumbing was the real issue.
#2295334 - 04/27/17 09:08 PM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
killermopar Offline
Loc: Spencer NY
Holy cow that looks neat. The way I love to see stuff. Great job, keep up the good work. The progress is moving quick on this one.
#2295416 - 04/27/17 11:32 PM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
Here is plumbing in the waste gates.
#2295421 - 04/27/17 11:36 PM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
Building the driver side exhaust was a challenge. Found some very tight stainless U-bends on ebay that worked great.
#2295422 - 04/27/17 11:38 PM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
Connecting in the waste gate on the driver side.
#2295426 - 04/27/17 11:42 PM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
The waste gate and turbo outlet section pre and post jethot coated. Used their ultra high temp so I did not have to worry about "burning off" the standard coating while dialing in the tune. Also was trying to keep as much heat in the exhaust instead of cooking the fiberglass hood.
#2295930 - 04/29/17 02:07 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
With all the coated items back in. Running all the oil and cooling lines to the turbos done. Finishing up the heater hoses.
#2295931 - 04/29/17 02:09 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
In this picture it shows how little room there is with the fans in. The waste gates actually fit into the shroud in spots.
#2298126 - 05/03/17 01:53 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
Mocking up the Throttle body ducting.
#2305934 - 05/17/17 08:01 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
TiMopar Offline
Loc: uk
Very nice build, look forward to seeing this finished! If you don't mind my saying so, the old radiator looks a little out of place now : )) Good luck!
#2313264 - 05/29/17 08:07 PM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
Here is a pic with the done engine compartment. Yes, the stock radiator is not as flashy as the rest but I have had issues with aluminum ones in the past and this one works great.
#2313435 - 05/30/17 08:21 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
rocksmopar Offline
Loc: Chicago
Looks like a beast with A/C !!
Searching for affordable E-Body parts
#2314054 - 05/31/17 07:11 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
TiMopar Offline
Loc: uk
Looks great, how does it go???
#2315457 - 06/03/17 12:59 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
It runs good. Running low boost as its a stock block, rods and crank. Had it chassis dyno'd and it has 516hp and 582ft lbs of torque at the wheels at 9psi boost.
#2315458 - 06/03/17 01:17 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
Here is the inside with the sound deadener installed. Raised the rear of the tunnel a little so it can sit a little lower and not have any issues hitting the yoke or driveshaft
#2315459 - 06/03/17 01:19 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
Here is a view of the magnaflow exhaust from the rear.
#2315460 - 06/03/17 01:20 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
Front view.
#2315461 - 06/03/17 01:26 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
Here is a view of one inner fender. Above the intercoolers there is a air pump (smog) from a modern can re-purposed as crank case vac's. One each side connected to each valve cover. I have the PCM control them through a pulse width module. From 500rpm to 2000rpm they run at 30%. From there they ramp up to 100% by 3500rpm.
#2315462 - 06/03/17 01:28 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
Side view. I went with a satin finish where flat/semi gloss would normally be (hood,stripes,spoiler,tail panel) for a more modern touch.
#2315463 - 06/03/17 01:30 AM Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab]
slowfab Offline
Loc: California
rear
25,743 Registered Members
193,023 Topics
Who sells A-Body Rear Leaf Spring Rebuild Kits?
by vinnyd76
02/22/19 09:58 AM
Rich Edelebrocks
by moparjack44
02/22/19 09:37 AM
Converting a 12 volt battery to 16 volt
by Sammy
02/22/19 08:50 AM
What brand Ring & Pinion are you running in your 8.75 rear?
by vinnyd76
02/22/19 08:49 AM
