Fourspeed Reverse Light #2290287
04/18/17 10:20 PM
04/18/17 10:20 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi. Do they sell a repair kit for the reverse light on a four speed ? The rubber boot is bad. Thanks.
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Fourspeed Reverse Light [Re: GTXKARL] #2290341
04/18/17 11:57 PM
04/18/17 11:57 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
How you doing Karl, this is Kevin, hope the trunk light is working. What boot are you talking about? If it is the one down at the trans then chances are Brewer's or Passion sells a reverse light harness that would include the boot, if you are talking about the boot where the wire comes through the firewall, same deal. If there is another boot I'm not thinking of then tell us which one and maybe someone will have a suggestion. I may have a lower one at the house but not sure exactly where.
Careful, your character's showing!
Re: Fourspeed Reverse Light [Re: GTXKARL] #2290751
04/19/17 10:38 PM
04/19/17 10:38 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hey, Kevin. We got it at the club car meeting. The light does work that you gave me. I put it in. Then, I realized that I had a problem with the light. I have to leave it unplugged or the battery will die. Thanks again. On topic now. The boot holds the wires for the reverse lights at the manual transmission. I am trying to buy a new pig tail. I don't want to replace the wire harness. Its just dried out and hard. Thanks again.
Re: Fourspeed Reverse Light [Re: GTXKARL] #2290780
04/19/17 11:56 PM
04/19/17 11:56 PM
mopar346 Offline
mopar346  Offline
If I'm not mistaken the wire to the reverse light switch is a separate jumper harness and does not require the replace of the engine harness but just the small harness.
I was kinda right:
http://www.brewersperformance.com/proddetail.asp?prod=BLH
It is a separate little harness but it does require that you pull the bulk head connector and release the terminals and plug the new wires in. Simple enough to do, I could do it in minutes if I was in town just not sure when that would be. Tim or Andy could do it quickly as well and I'm sure they would. You could replace harness and just have it hanging at the bulk head for them to stop by.
Good luck!
Re: Fourspeed Reverse Light [Re: GTXKARL] #2290923
04/20/17 11:14 AM
04/20/17 11:14 AM
Maryland
MoparMike1974 Offline
Maryland
Rockauto has the pigtail for $12.42
Just splice it in. http://www.rockauto.com/en/moreinfo.php?pk=4673376&cc=1499090&jsn=425
Those rubber plugs are always hard as a brick.
Re: Fourspeed Reverse Light [Re: MoparMike1974] #2291054
04/20/17 03:31 PM
04/20/17 03:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
OP has 4-speed, not auto.
Re: Fourspeed Reverse Light [Re: John_Kunkel] #2291231
04/20/17 09:11 PM
04/20/17 09:11 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi John
Can you tell what OP is thank you
Re: Fourspeed Reverse Light [Re: GTXKARL] #2291245
04/20/17 09:31 PM
04/20/17 09:31 PM
mopar346 Offline
mopar346  Offline
OP means original poster ---- you started the thread.
Not to mention Karl's car is nice/original enough that he doesn't need to spline wires, he will want to fix it as correctly as possible.
