Page 1 of 3 1 2 3
470 ci project underway!! Pistons and girdle install #2288125
04/15/17 11:31 AM
04/15/17 11:31 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Just got the 400 block back from Automotive Machine in Fraser, Mi boogie
These guys do quality work and are EASY to deal with. Just sprayed a fresh coat of insulator paint in the block and will get the crank installed next......
Re: 470 ci project underway [Re: ccdave] #2288126
04/15/17 11:33 AM
04/15/17 11:33 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Looks great. up Ron
Re: 470 ci project underway [Re: 383man] #2288135
04/15/17 11:48 AM
04/15/17 11:48 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
can you share your plans for the rest of the combo? up
Re: 470 ci project underway [Re: bonefish] #2288148
04/15/17 12:04 PM
04/15/17 12:04 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
This motor will be in a 70 Roadrunner 5 speed with 3.91 gears. The motor has the following:
Molnar 3.91 crank
Diamond custom pistons 10:9 CR
Molnar 6.535 H beam rods
Std port Victor heads gen 3 castings if I ever get them from Edelbrock flame
Hughes Hyd roller
Hughes rockers
Performer rpm intake
Holley 950 Ultra HP
TTI 1" 7/8's headers
Re: 470 ci project underway [Re: ccdave] #2288160
04/15/17 12:22 PM
04/15/17 12:22 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Nice starting point. Good luck with the build.
[image][/image]
Re: 470 ci project underway [Re: ccdave] #2288243
04/15/17 02:50 PM
04/15/17 02:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Re: 470 ci project underway [Re: ProSport] #2291941
04/22/17 02:18 AM
04/22/17 02:18 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Crank installed!!!!! I made a few mods to the SDC caps to make installation easy. A bevel was milled into the edge of the cap for easier install and less galling on the cap into the block registers. I also removed material from the inside of the washer countersink on the caps so the socket fits onto the nuts without the caps material interfering. Lastly I drilled out the #3 cap to 17/32 for easier thrust adjustment. I also brushed moly onto the cap edges and block registers to help prevent galling.
Crank is in!
Re: 470 ci project underway [Re: ccdave] #2291946
04/22/17 02:28 AM
04/22/17 02:28 AM
Wisconsin
StageIII Offline
StageIII  Offline
Wisconsin
Who's main caps are you using?
Re: 470 ci project underway [Re: StageIII] #2291949
04/22/17 02:33 AM
04/22/17 02:33 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
SDC
Re: 470 ci project underway [Re: ccdave] #2292042
04/22/17 12:35 PM
04/22/17 12:35 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Crank install!!!!!
Re: 470 ci project underway!! Crank install [Re: ccdave] #2292049
04/22/17 12:44 PM
04/22/17 12:44 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
thumbs
Re: 470 ci project underway [Re: ccdave] #2292051
04/22/17 12:46 PM
04/22/17 12:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lookin good man..............
Re: 470 ci project underway [Re: ccdave] #2292068
04/22/17 01:12 PM
04/22/17 01:12 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Looks good thumbs
Did you take the time to install the rear seal retainer, line up the seal grooves and make reference marks for proper location before the crank went in?
Re: 470 ci project underway [Re: roadhazard] #2292073
04/22/17 01:19 PM
04/22/17 01:19 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Yes whistling
That's a good one up
Re: 470 ci project underway [Re: ccdave] #2292083
04/22/17 01:30 PM
04/22/17 01:30 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Originally Posted By ccdave
Yes whistling
Thanks for paying attention bow
It's the small details that add up to complete satisfaction.
Good looking build!
Re: 470 ci project underway [Re: ccdave] #2292141
04/22/17 03:35 PM
04/22/17 03:35 PM
Do not use any lube or any other materials between the mating surface, all of them, of the block and main caps tsk tsk tsk
They need metal to metal contact only to mate, center and hold the caps in properly up twocents
Re: 470 ci project underway [Re: ccdave] #2292155
04/22/17 03:57 PM
04/22/17 03:57 PM
P
Porter67 Offline
Porter67  Offline
P
What brand main studs are those?
Re: 470 ci project underway [Re: Porter67] #2292158
04/22/17 03:59 PM
04/22/17 03:59 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Those are ARP's up
Re: 470 ci project underway [Re: Cab_Burge] #2292162
04/22/17 04:08 PM
04/22/17 04:08 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Got it up
But I just love the silky smooth moly brushed up against the aluminum caps drool
The caps glide into the cap regesters like butter and no chafing popcorn
Mmmmm boogie
Re: 470 ci project underway [Re: ccdave] #2292434
04/23/17 12:02 AM
04/23/17 12:02 AM
You will be sorry shruggy
Did you use the lube on the caps like that when you measure the bearing to crank clearances ? If so you got a false reading shruggy
Page 1 of 3 1 2 3
