Page 1 of 4 1 2 3 4 >
#2287275 - 04/13/17 07:29 PM 315 Square setup E-body `Cuda
RylisPro Offline
Loc: NorCal
I flat spotted my BFG Rivals last week at Big Willow. Was doing 135 and stomped on the brakes hard to avoid rear ending a 68 Barracuda.
My 295's were getting old anyways and needed to be switched out. Plenty of tread left but they have been heat cycled out from all the track days I put them through.
Height difference of 295 vs 315 mounted on a 10.5" rim.
I was fairly certain the 315's would hit the leaf spring or the upper inner wheelwell but to my suprise it does not rub anywhere.View of passenger rear.
View of upper inner wheelwell. Plenty of clearance.
View of passenger rear fender. I might fold the lip up if I have any issues but there is lots of clearance here too.
Here is the driver front with the steering turned full lock to the right. Nothing hits with tons of room.
Another view of driver front. I haven't gotten an alignment yet and can still get more negative camber if needed.
I do admit that a 10.5" wheel is not the best size for a 315/30-18 BFG Rival S. An 11" or 11.5" would be ideal to maximize the contact patch. The 10.5" does sink in deep enough that the tire acts as a rim protector though!
/Drive
Instagram: @rylispro
YouTube:RylisPro
www.rylispro.com
925-214-9192
Tremec T56 Magnums & Quick Time bells
Lightened Billet Steel Flywheels
Prefix Performance
#2287276 - 04/13/17 07:29 PM Re: 315 Square setup E-body `Cuda [Re: RylisPro]
RylisPro Offline
Loc: NorCal
View of passenger front with wheel turned straight ahead. Plenty of space at the fender.
I can still fit my hand in between.
View of passenger front tire. That is nearly 12 inches of contact patch!
Rear view.
295 vs 315
Anyone want a set of skinny 295's? haha! They are going on Craiglist for cheap!
There it is fellas a 315 square setup Ebody. As anyone who has seen my car at the Spring Fling track days can vouch that there is nothing fancy or complicated about my setup. All it takes is careful measurements and custom offset wheels and I'm certain this will apply to Challengers and B bodies as well!
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#2287278 - 04/13/17 07:35 PM Re: 315 Square setup E-body `Cuda [Re: RylisPro]
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
Loc: On The Boat, On The Lake, Wa. ...
You are suppose to square the tire sizes, not the 'roundness' of the tire circumference. eek
Did ya scare the Barracuda driver? It wasn't Steve was it? devil
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
#2287292 - 04/13/17 07:58 PM Re: 315 Square setup E-body `Cuda [Re: RylisPro]
boydsdodge Offline
Loc: Toronto, Ont, Canada
Good save, I was wondering if you flat spotted.
Fun day tho, glad you made it out again.
#2287307 - 04/13/17 08:27 PM Re: 315 Square setup E-body `Cuda [Re: RylisPro]
GoodysGotaCuda Offline
5.7L Hemi, 6spd
Loc: Texas
That's a lot of tire, looks nearly certain that the leaf spring will hit, unless you have delrin or very rigid bushings.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
1969 Dodge Dart Custom Sedan - Grandma Edition - 318/904
2016 Subaru WRX - E30 Tune ~320whp
#2287320 - 04/13/17 08:44 PM Re: 315 Square setup E-body `Cuda [Re: GoodysGotaCuda]
RylisPro Offline
Loc: NorCal
The camera angle is just bad on that pic, here is a better view
Passenger rear
Driver rear
It's tight but there is enough clearance where it will not cause any interference with the leafs. Even if it does I still have 3mm spacers that can push the wheel out a little.
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#2287371 - 04/13/17 10:01 PM Re: 315 Square setup E-body `Cuda [Re: RylisPro]
MuuMuu101 Offline
I got lucky at Woodward!
Loc: Covina, Ca
I don't think the 295's will fit under my Dart without major surgery and new wheels. Heck, I'm even having problems with 255's.
68 Dart GT Project Thread: Linky!
#2287601 - 04/14/17 10:05 AM Re: 315 Square setup E-body `Cuda [Re: RylisPro]
NV69B7RR Offline
Loc: Reno, Nevada
Thats a lot of tire, looks mean. I'd take the 295's if you were closer, I could use them for fitment clearance on my Demon as I'm trying for square 315's on it.
What kind of rims do you have Ariel? I really like the looks of them.
68 AMX track car
72 Demon 340
71 Duster 340 Resto http://board.moparts.org/ubbthreads/show...part=1&vc=1
#2287637 - 04/14/17 11:04 AM Re: 315 Square setup E-body `Cuda [Re: NV69B7RR]
RylisPro Offline
Loc: NorCal
Hey Brent!
The rims I run are Forgeline GS1R's
http://www.forgeline.com/products/competition-series/gs1r.html
The Red Brick would look badass with a set of these! Talk to Mark Schetter and he'll sell them for less than on the website.
I also have a pair of Enkei wheels w/ 295 BFG KDW's that I let people borrow for fitment. A 315 is only about an inch wider( 1/2" per side) than a 295. Reno isn't that far!
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#2287640 - 04/14/17 11:09 AM Re: 315 Square setup E-body `Cuda [Re: RylisPro]
amxautox Offline
1500 a wheel??? eek Sorry, not going to happen. Guess I'll be limited to minilight wheels some day.
Tom
author unknown
#2287668 - 04/14/17 11:58 AM Re: 315 Square setup E-body `Cuda [Re: RylisPro]
Jerry Offline
Loc: Warren, MI
look at ford racing wheels as well. if you can get a hub centric spacer made to fit your wheel and your car they will be plenty strong as well.
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
#2287847 - 04/14/17 06:23 PM Re: 315 Square setup E-body `Cuda [Re: RylisPro]
5.7L Hemi, 6spd
Loc: Texas
Driver rear
Looks better. Is the gap equal side to side? Appears to have more clearance on one side vs the other.
#2287869 - 04/14/17 07:08 PM Re: 315 Square setup E-body `Cuda [Re: GoodysGotaCuda]
RylisPro Offline
Loc: NorCal
The gap is tighter on the passenger side by about 1/8". It's because how my perches were welded.
No big deal though
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#2287900 - 04/14/17 08:25 PM Re: 315 Square setup E-body `Cuda [Re: RylisPro]
NV69B7RR Offline
Loc: Reno, Nevada
No wonder this e wheels look so good, Forgelines are some of the best wheel out there! I know I'll be heading down that way in early June for the Sonoma Historics, so if you don't sell the tires by then I'll pick them up.
I'm thinking of buying this tool for measuring wheel offsets once you have the tire size chosen.
https://www.summitracing.com/nv/parts/wwk-10724568/overview/
I'll rent it out to recoup the cost.
68 AMX track car
72 Demon 340
#2287959 - 04/14/17 09:47 PM Re: 315 Square setup E-body `Cuda [Re: NV69B7RR]
RylisPro Offline
Loc: NorCal
I feel tools like those are garbage because you cannot put the entire weight of the car down on them and set the ride height. Nothing beats a deep offset wheel with a variety of spacers to fine tune measurements. With a physical wheel and tire you can roll the car around, turn the wheel lock to lock and be dead on when the time comes to drop down for the actual rims.
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
Prefix Performance
#2288024 - 04/14/17 11:46 PM Re: 315 Square setup E-body `Cuda [Re: RylisPro]
mopardamo Offline
Loc: St. Louis, MO
Some overall Picts of the look would be great!
New 528 Bullet for 71 Challey
#2288038 - 04/15/17 12:25 AM Re: 315 Square setup E-body `Cuda [Re: RylisPro]
NV69B7RR Offline
Loc: Reno, Nevada
True and good points. You can get pretty close with that tool by pulling the t bar and shock and cycling the suspension and steering. But the pics above are proof that your way works well!
68 AMX track car
72 Demon 340
#2288060 - 04/15/17 01:47 AM Re: 315 Square setup E-body `Cuda [Re: NV69B7RR]
HUSTLESTUFF Offline
Loc: NORTHERN CA
I have and used one of those on my Charger. I have a lift and just jacked up the suspension and put most of weight on it. I think it's a good tool. Could probably loan with deposit.
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
#2288094 - 04/15/17 07:42 AM Re: 315 Square setup E-body `Cuda [Re: amxautox]
moparx Offline
Dreaming of implants
Loc: north of coder
some time ago i made this statement : "i'm NEVER gonna pay $250.00 for a SET of tires AND wheels ! that's just a RIDICULOUS amount !" uh, well, i guess i'm showing my age....... grin i have since had to rethink that statement..........
beer
#2288246 - 04/15/17 12:56 PM Re: 315 Square setup E-body `Cuda [Re: moparx]
amxautox Offline
beer
Yup, sometimes we change our minds, but I'll NEVER have that kind of money. Well, not until I win the lotto. I can't even save 1600 for something I want for the boat, without some crap happening and taking most of that money that I do/did have saved. I have no real idea what the new well house and new water holding tank will cost me over this summer, at least 1500, and maybe 3,000. at least the ramcharger has new tires even if I can't get to the lake very often this summer.
Tom
author unknown
25,538 Registered Members
194,122 Topics
FMC Wheel Balancer
by 6PakBee
41 minutes 31 seconds ago
A little testing yesterday
by one bad fish
52 minutes 3 seconds ago
1941 Dodge Pickup Project
by Neil
Today at 09:54 AM
Dark argent spray paint
by 6PAX
Today at 08:53 AM
