Building a 5.7 stroked to 6.1 #2285982
04/11/17 07:30 PM
04/11/17 07:30 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
So I need timing set and oil pump. Going with the 6.1 stuff.
Where is the best place to get it? Rock auto melling or mopar?
This engine is going to be 99% street duty
Combo is 6.4 crank turned to 3.79
5.7 block bored .020 over
Early 5.7 heads ported with 6.1 valves and new seats.
stock 6.1 cam
9.8 comp.
Thx Matt
Re: Building a 5.7 stroked to 6.1 [Re: MattW] #2286291
04/12/17 10:11 AM
04/12/17 10:11 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Sounds like a nice little combo, what's it going in?
Re: Building a 5.7 stroked to 6.1 [Re: WO23Coronet] #2286375
04/12/17 12:58 PM
04/12/17 12:58 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
03 Dakota.
Been reading up on the oil pumps.
Do I need the 6.1 or I'd a standard 5.7 good enough?
They say that the 6.1 gets rid of the famous hemi tick.
Matt
Re: Building a 5.7 stroked to 6.1 [Re: MattW] #2286409
04/12/17 01:53 PM
04/12/17 01:53 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Absolutely go with the Melling M362 6.1 Hemi oil pump. I got it the cheapest at Rockauto. You can easily find Rockauto 5% off coupon codes that will help offset shipping costs. The 6.1 pump will give you more oil supply, most importantly, at lower RPMs and save you from eating your bearings long term...
SuperBeast
An enforcer for the Mopar Mafia!
