Indy heads in a A body #2285887
04/11/17 04:27 PM
04/11/17 04:27 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Is there an off the shelf header that will work to put a 440 into a mopar A body (75 Duster) with Indy -1 heads? I see TTI does not offer one that will work "without alot of modification". The car has the fenderwell removed, but still has the stock k-frame, steering box, etc. Does have the bars from the cage tied into the upper shock mount and front frame rail. Didn't know if hooker fenderwells or Proparts or another brand would work.
Re: Indy heads in a A body [Re: DusterKid] #2285909
04/11/17 05:30 PM
04/11/17 05:30 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I have pro parts on mine, no problem
Re: Indy heads in a A body [Re: DusterKid] #2285920
04/11/17 05:51 PM
04/11/17 05:51 PM
AndyF Offline
AndyF  Offline
TTi has headers that fit that application.
Re: Indy heads in a A body [Re: DusterKid] #2285932
04/11/17 06:09 PM
04/11/17 06:09 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
440-200-C1 or 440-200-C4 TTI will fit with 440-1 heads.The cataloge says 70 to 74 but we have put them on the 75 also.
Re: Indy heads in a A body [Re: DusterKid] #2285965
04/11/17 07:07 PM
04/11/17 07:07 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
There you go. Order them through a reputable dealer who supports Moparts and their customers... Call AJ at BG Racing!
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Indy heads in a A body [Re: DusterKid] #2286282
04/12/17 09:37 AM
04/12/17 09:37 AM
Keymar, MD
Keymar, MD
I have a set of TTI 2" on the car now, but I didn't think they would work with 440-1 heads since they have raised exhaust ports, but guess I was wrong. That's good news. Thanks.
Re: Indy heads in a A body [Re: DusterKid] #2286341
04/12/17 11:59 AM
04/12/17 11:59 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Pro-parts for me
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
