Re: Which Roller Rockers to run with the 240 Trick Flow Heads?
[Re: 70RT Charger]
#2285556
04/10/17 10:42 PM
04/10/17 10:42 PM
Posts: 30,994 Oregon
AndyF
The Mancini rocker arms work just fine. The Mancini rocker arms are built by Harland but are designed to have the same dimensions as the old Crane rocker arms. I think most any rocker arm will fit the 240 heads. Stock stuff might work, Isky nodulars should work, etc. The deal with the 240 heads is that you need different studs and you might need to tweak the hold downs to get everything lined up correctly. http://www.hotrod.com/articles/trying-find-extra-power-rocker-arm-testing/
[Re: AndyF]
#2285613
04/11/17 12:30 AM
04/11/17 12:30 AM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
The Mancini rocker arms work just fine. The Mancini rocker arms are built by Harland but are designed to have the same dimensions as the old Crane rocker arms. I think most any rocker arm will fit the 240 heads. Stock stuff might work, Isky nodulars should work, etc. The deal with the 240 heads is that you need different studs and you might need to tweak the hold downs to get everything lined up correctly. http://www.hotrod.com/articles/trying-find-extra-power-rocker-arm-testing/ OK. When you say different studs are you talking about the head bolts because I ordered them from TF with the heads. So do I need the 1.6 Rockers then and I'll be running a RPM performer intake also. Should I run around an 850 carb also? Sorry for all of the questions. Thanks a lot!
[Re: RustyM]
#2285669
04/11/17 03:08 AM
04/11/17 03:08 AM
Posts: 636 Graz, Austria
DGS
Graz, Austria
The studs are the rocker shaft studs- can get from Trick Flow as well. Do you have a part number for the studs? I know Andy uses different studs than those in the official stud kit but I haven't been able to get a part number yet. Thanks
