What size brake lines with Wilwood calipers? #228523
02/18/09 10:27 AM
02/18/09 10:27 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
I have installed Wilwood front calipers on my project car. Drums will be used on the rear. what size brake hoses should I use on the front calipers? I already have some AN#4 hoses and would like to use them if they will work OK. The master cylinder is a stock one for a 73 disc brake A-body. Thanks you in advance for your experience/replies. Jim
Re: What size brake lines with Wilwood calipers? [Re: rt66jim] #228524
02/18/09 11:10 AM
02/18/09 11:10 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I used these
Re: What size brake lines with Wilwood calipers? [Re: WILD BILL] #228525
02/18/09 01:08 PM
02/18/09 01:08 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
WildBill thanks for that link. I see those are #3 lines. I'm just wondering if the #4 lines that I already have would be too big? Jim
Re: What size brake lines with Wilwood calipers? [Re: rt66jim] #228526
02/18/09 01:26 PM
02/18/09 01:26 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I thought fluid pressure would stay the same, ina slightly larger line, and just push extra volume by the MC.
Re: What size brake lines with Wilwood calipers? [Re: Bob_Coomer] #228527
02/18/09 01:35 PM
02/18/09 01:35 PM
Q
Quicktree Offline
Quicktree  Offline
Q
3/16 - #3 an works fine
Re: What size brake lines with Wilwood calipers? [Re: rt66jim] #228528
02/18/09 01:46 PM
02/18/09 01:46 PM
AndyF Offline
AndyF  Offline
#4 will work for brakes as long as the lines are capable of handling the pressure. #3 is usually used for brake lines since it is stronger.
Re: What size brake lines with Wilwood calipers? [Re: AndyF] #228529
02/18/09 03:17 PM
02/18/09 03:17 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
