Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 #2284838
04/09/17 03:24 PM
04/09/17 03:24 PM
ghinmi Offline OP
ghinmi  Offline OP
Hit up the track yesterday with surprising results. Combo is a 2010 Challenger 5.7/6 speed. Cable drive throttle body, vvt disabled, 80 lb injectors, Bullseye 66mm turbo with 7 psi on 93 pump gas. Jeep weighs 3990 lbs. The 11.14 was on a really soft launch, by the time I started gaining on it the transmission wasn't playing nice so no 10s yet. This little 5.7 is a workhorse, I'm impressed with it. Made 535 to the tire at 5500 rpm last weekend.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2284953
04/09/17 07:19 PM
04/09/17 07:19 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
thumbs First time to the track with it?
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2284995
04/09/17 08:31 PM
04/09/17 08:31 PM
ghinmi Offline OP
ghinmi  Offline OP
No, I've gone a couple times with this one and also did Drag Week with it last year. Just picked up a bunch of mph since last time. Previous best was an 11.46 @ 120.2
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285143
04/10/17 02:25 AM
04/10/17 02:25 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
What is the story on the engine? Aftermarket stuff? Heads ported??
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285148
04/10/17 02:35 AM
04/10/17 02:35 AM
ghinmi Offline OP
ghinmi  Offline OP
Just the vvt locked out, injectors, throttle body, and truck oil pan to clear the crossmember. The front cover has been off to lock the vvt but aside from that the motor has never been apart. Still on the original spark plugs that I re-gapped to .030 because it was blowing out spark. It's actually on the original clutch as well. Motor and trans have roughly 63k miles on them, 6500 of those with the turbo setup.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285240
04/10/17 12:01 PM
04/10/17 12:01 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That is an awesome combo man, looks like fun.
68 Barracuda Formula S 340
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285260
04/10/17 12:35 PM
04/10/17 12:35 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
What frame/suspension are you using?
Have a great day
Iowan
"obsolete is neat"
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285317
04/10/17 02:42 PM
04/10/17 02:42 PM
State College, Pennsylvania
fatman Offline
fatman  Offline
Thanks for posting, this is a favorite of mine.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285578
04/10/17 11:32 PM
04/10/17 11:32 PM
ghinmi Offline OP
ghinmi  Offline OP
Thanks! I know it won't be the most popular here but it's on a '71 Chevy C10 chassis shortened 17" and reworked suspension. The whole truck is a mutt, whatever works and is cheap.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285797
04/11/17 12:59 PM
04/11/17 12:59 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Very cool build. Run what you've got. Wish my Challenger would run like that.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2285870
04/11/17 03:52 PM
04/11/17 03:52 PM
Renton Washington
Triple Threat Offline
Renton Washington
That's a sweet build and it runs hard. Congrats!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2296254
04/29/17 10:22 PM
04/29/17 10:22 PM
ghinmi Offline OP
ghinmi  Offline OP
Drove it to the track again yesterday and put the best stats from those two slips together. Went 1.57 sixty and 10.97 @ 125.2 on the first pass. Slapped on the 315/35r17 hard street tires and managed a 1.99 sixty, 11.50 @ 124.2 on the second attempt. Super happy with this simple motor combo.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2296347
04/30/17 01:33 AM
04/30/17 01:33 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
That is a beast man. Nice, "simple", and working like a champ...
SuperBeast
An enforcer for the Mopar Mafia!
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2303032
05/11/17 09:32 PM
05/11/17 09:32 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I was going to say you have the mph for 10's. I know boosted cars usually mph more then N/A as I am but glad to see you got your 10. It seems N/A usually 60 ft a little better then boosted cars also but you are running real good. Ron
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: 383man] #2303399
05/12/17 03:55 PM
05/12/17 03:55 PM
ghinmi Offline OP
ghinmi  Offline OP
Yep, there's definitely a good bit left in it with a good clutch and some suspension changes. I just don't want to sacrifice handling for et since it's built to do autocross with. The 11.50 was in full autocross trim and the 10.97 was just a tire swap, no suspension changes.
I'm still amazed at the mph, it's 10 mph higher than I ever thought it would be.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2305831
05/17/17 01:09 AM
05/17/17 01:09 AM
SoCal
Frank Cannon Offline
SoCal
That's a cool truck.
CALIFORNIA-SUNDAY-10:04 A.M.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2306365
05/17/17 10:50 PM
05/17/17 10:50 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Great job. I love how simple it is, and just plain works!!
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2306873
05/18/17 05:30 PM
05/18/17 05:30 PM
ghinmi Offline OP
ghinmi  Offline OP
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2325990
06/24/17 01:47 AM
06/24/17 01:47 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Awesome.... smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2580655
11/20/18 03:27 PM
11/20/18 03:27 PM
ghinmi Offline OP
ghinmi  Offline OP
Some updates. The red Jeep got wrecked last summer and I built a new one. Same drivetrain. Did pistons/rods and no other changes other than upping the boost. The little 5.7 and s366 keeps performing. Has been 10.90 @ 130 on the low profile Continental street tires and 10.38 @ 132.6 on a 28x10.5 slick. The 10.38 pass was actually very soft, only went 1.56 sixty foot because the clutch was on it's way out. Has been 1.46 so should go a good bit quicker with all that mph in the Spring.
Also drove it from Michigan to Atlanta, did Drag Week, and drove it home. 2805 miles in a week and 13 passes.
Have also done some autocrossing with it, you can see how linear the power is and how little lag the tiny turbo has.
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2580778
11/20/18 09:20 PM
11/20/18 09:20 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
What pistons/rods and how much compression/boost now? New clutch and 9s next? thumbs
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2580782
11/20/18 09:31 PM
11/20/18 09:31 PM
Renton Washington
Renton Washington
What does it weigh?
-Dustin
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2580890
11/21/18 01:06 AM
11/21/18 01:06 AM
ghinmi Offline OP
ghinmi  Offline OP
It's got the MMX drop in piston/rod package. I actually didn't even figure the compression, just slammed them in and sent it. Quick and dirty. It didn't really need them but I just felt more comfortable having them for Drag Week because I'd be so far from home with no backup plan.
I actually put another Hellcat clutch in it a couple days ago. Not sure that it's got enough steam to go 9s but it keeps getting faster so who knows? Definitely didn't expect the 66mm to make as much power as it already has.
It's just a shade under 4000 lbs usually. Was 3960 right after the 10.38 pass.
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2580975
11/21/18 09:49 AM
11/21/18 09:49 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
love this thing.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2581232
11/21/18 07:38 PM
11/21/18 07:38 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
How much boost are you running now? I'm building a similar combo, little bigger turbo and lighter vehicle... it may end up being quicker than I realize based on what yours run.
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2581242
11/21/18 08:19 PM
11/21/18 08:19 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Me likey, fun ride.
"Just a Bracket car dressed up like a streetcar"
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: Just-a-dart] #2581308
11/21/18 10:53 PM
11/21/18 10:53 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
How cool is that!!! Nice ride!!
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2581333
11/21/18 11:32 PM
11/21/18 11:32 PM
IL
furious70 Offline
furious70  Offline
IL
How much boost/power did you end up making with the stock engine?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Eagle 5.7 with boost 11.14 @ 125.5 Edit: now 10.38 @ 132.6 [Re: ghinmi] #2581638
11/22/18 06:44 PM
11/22/18 06:44 PM
ghinmi Offline OP
ghinmi  Offline OP
The quick pass was on 16 psi. It'll make more but goes slower, all out of turbo. With some fuel pulled out of it I think I can squeak some more boost out of it. And add some timing too. It's a very, very conservative tune.
On the stock stuff it had been 10.50s @ way less mph and a ton better sixty. I forget the mph, sub 130 though. I want to say it was at 10ish psi. It was picking up big power with timing increases but I was afraid of the stock stuff.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2592525
12/15/18 09:02 PM
12/15/18 09:02 PM
raleigh, NC
mcmopar1 Offline
mcmopar1  Offline
raleigh, NC
Engine compartment pic? Turbo location?
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2596351
12/24/18 04:41 PM
12/24/18 04:41 PM
IL
furious70 Offline
furious70  Offline
IL
I've got a 76mm T6 that I was going to build an EZ headed 400 from parts I have for my Coronet, but thinking more and more about the 5.7. I'm interested in just taking an OEM pull out and starting rather than building one, don't need crazy power (yet). Just a step up from my Fury's very docile turbo setup.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: mcmopar1] #2596646
12/25/18 03:48 AM
12/25/18 03:48 AM
ghinmi Offline OP
ghinmi  Offline OP
The turbo in the red one was passenger side up by the firewall, blue one is passenger side front mount.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2597319
12/26/18 10:15 PM
12/26/18 10:15 PM
IL
furious70 Offline
furious70  Offline
IL
What engine management are you using?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2597515
12/27/18 12:14 PM
12/27/18 12:14 PM
ghinmi Offline OP
ghinmi  Offline OP
It's on holley HP efi. I went with the cable drive throttle body so that I didn't need the Dominator. Kind of wishing I would have sprung for the extra money now for the extra inputs and outputs.
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: ghinmi] #2597862
12/28/18 02:31 AM
12/28/18 02:31 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
That is the coolest Jeep ever! What wheel and tire setup are you using for autocross. Looks awesome!
Re: Eagle 5.7 with boost 11.14 @ 125.5 [Re: MuuMuu101] #2598009
12/28/18 03:37 PM
12/28/18 03:37 PM
ghinmi Offline OP
ghinmi  Offline OP
Thanks! For autocross and street I've got 17x11 C4 Corvette ZR1 wheels. Cheap and effective. And 275/40zr17 Continental ExtremeContact Sports. It's a tradeoff, I could go a bunch bigger but nobody makes a good 17" tire in wide sizes and the 18" stuff gets expensive. It's working pretty good for the budget wheels/tires though.
