66 Sport Fury- Disc Brake conversion #2282745
04/05/17 11:29 AM
04/05/17 11:29 AM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Can anyone reccomend a front disc brake conversion kit for 55 Sport Fury?
Client wants front discs for street car/ cruiser .
Rusty
Re: 66 Sport Fury- Disc Brake conversion [Re: RustyM] #2282765
04/05/17 12:21 PM
04/05/17 12:21 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Ive done three 65 Sport Fury conversions. Ive used the Scarbird kit and it was OK but probably wouldn't use it again. I also have the SSBC and it is a nice setup. The best one I did was using the original 73 fury front disc setup, spindles and all, nice but hard to find. I would go with the SSBC again.
Re: 66 Sport Fury- Disc Brake conversion [Re: RustyM] #2282767
04/05/17 12:29 PM
04/05/17 12:29 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Thanks.
I had looked at that and, a friend has their kits on 65 and a 66 Newport.
No problems
Re: 66 Sport Fury- Disc Brake conversion [Re: RustyM] #2284278
04/08/17 02:44 AM
04/08/17 02:44 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'd go with the 69-73 factory spindles and 11.75" rotors.
The 73 spindle is the preferred one because the rotor is/was cheaper than the earlier 2 pce one. It is my understanding that they are machining the unicast rotor to fit the early spindle so they are cheaper than when they were 2 piece.
The only difference between the early and late setup is the bearing size on the rotors. All the other parts are the same.
Kevin
Re: 66 Sport Fury- Disc Brake conversion [Re: Twostick] #2294772
04/27/17 12:07 AM
04/27/17 12:07 AM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Thanks Kevin.
Re: 66 Sport Fury- Disc Brake conversion [Re: RustyM] #2305908
05/17/17 08:30 AM
05/17/17 08:30 AM
MN
Skid_Demon Offline
Skid_Demon  Offline
MN
I am planning on the same disc brake swap for a 66 Newport. Curious why you wouldn't use the scarebird swap again? Thanks
Re: 66 Sport Fury- Disc Brake conversion [Re: Skid_Demon] #2306051
05/17/17 01:39 PM
05/17/17 01:39 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Its not a bad set-up and works fine, but I like the original 1973 Chrysler set up much better, but getting hard to find. The SSBC would be my choice over Scarbird, I was happy with the installation and performance of it.
Re: 66 Sport Fury- Disc Brake conversion [Re: RustyM] #2306380
05/17/17 11:12 PM
05/17/17 11:12 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
We used a 73 spindle on our 65 Sport Fury project. We made a bracket and used the SRT 14.25" rotor and gen 3 viper calipers. In the rear we used '12 Challenger SRT Rotors and Calipers and a drum in hat e brake. Fits like a glove on the 8.75" rear.
Re: 66 Sport Fury- Disc Brake conversion [Re: BergmanAutoCraft] #2306406
05/18/17 12:17 AM
05/18/17 12:17 AM
KY
65pacecar Offline
65pacecar  Offline
KY
Do you have pics of your 65 Sport Fury?
Re: 66 Sport Fury- Disc Brake conversion [Re: RustyM] #2308506
05/21/17 02:04 PM
05/21/17 02:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If by some miracle that's a '66 SF out of SoCal, light metallic blue/blue interior, maybe even a CA license SUW812, contact me.
Re: 66 Sport Fury- Disc Brake conversion [Re: RustyM] #2310509
05/24/17 06:35 PM
05/24/17 06:35 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
It's not.
I do have a numbers correct ( really, all numbers) 66 Sport Fury- factory ordered with 383 4bbl, factory AC.
Everything works, runs and drives- black car- deluxe interior , buckets, console etc.
Clock even works.
I would sell it.
Re: 66 Sport Fury- Disc Brake conversion [Re: RustyM] #2311153
05/25/17 08:46 PM
05/25/17 08:46 PM
Long Island, NY USA
Long Island, NY USA
Hopefully this works.
Re: 66 Sport Fury- Disc Brake conversion [Re: topside] #2311893
05/27/17 04:09 AM
05/27/17 04:09 AM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Someone steal your car Topside?
Re: 66 Sport Fury- Disc Brake conversion [Re: RustyM] #2312634
05/28/17 10:46 PM
05/28/17 10:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
No, it was my Dad's car; I just have some sentiment for it and hope it's still around somewhere. But if I found another in the same colors, I'd probably want to buy it.
Re: 66 Sport Fury- Disc Brake conversion [Re: RustyM] #2317580
06/07/17 11:51 AM
06/07/17 11:51 AM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Gotcha
