Wiper Motor
#2281712
04/03/17 04:39 PM
04/03/17 04:39 PM
Posts: 1,013 LEE, MASS
TOMRR
LEE, MASS
My wiper motor on my 69RR will not park, it was just rebuilt last year and has worked fine all summer ,Any Ideas??? Bad switch it is a 3-speed
Thanks Tom C.
Re: Wiper Motor
[Re: stinger]
#2281720
04/03/17 04:58 PM
04/03/17 04:58 PM
TOMRR
LEE, MASS
Make sure the wire harnes is in good shape. I just replaced mine to fix my park issue All New Wiring and have been working fine
Re: Wiper Motor
[Re: Stanton]
#2281743
04/03/17 05:40 PM
04/03/17 05:40 PM
TOMRR
LEE, MASS
Disconnect at the connector and jumper per the test procedure. This should isolate the problem to the motor or elsewhere. If it works, reconnect and try again. Sometimes things are just finicky. At the bulk connecter ?
Re: Wiper Motor
[Re: blewbyu]
#2281862
04/03/17 09:57 PM
04/03/17 09:57 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Check all of your grounds including the switch. Contact the rebuilder and see if they will fix it. If that doesn't work contact me and we'll get it fixed Bruce ns1aar.com
NS1AAR
Re: Wiper Motor
[Re: mattsmopars]
#2282297
04/04/17 04:17 PM
04/04/17 04:17 PM
TOMRR
LEE, MASS
In my experience a ground was the issue of not parking. Matt Thanks for the Reply , Was wondering where would those grounds be. I know there is one on the motor it self
