Re: LA with hemi heads?
[Re: emarine01]
#228100
02/17/09 09:16 PM
02/17/09 09:16 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
No. No hemi head will fit well on a small block. The closest would be a early hemi. It is pretty close and *could* be done by somebody with access to a machine shop but the cost outweights the benefit by a gigantic margin.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: emarine01]
#228109
02/18/09 11:34 AM
02/18/09 11:34 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Dont know much about the polys , are they big castings like the old hemis or light like a la block , can you get any cubes out of one?
If I remember right the LA bottom end will fit in a poly block but the block is wider than a LA block (the poly block was the original A engine)
[Re: SportF]
#228110
02/18/09 12:19 PM
02/18/09 12:19 PM
Posts: 4,206 New York
polyspheric
New York
Only Dodge hemi (241, 270, 315, 325) heads fit Dodge poly (241, 259, 315, 325) blocks. Only Chrysler hemi (331, 354, 392) heads fit Chrysler poly (301, 331, 354) blocks. No original hemi head, of any brand, fits Plymouth etc. poly A (277, 301, 303, 313, 318, 326) or LA (273, 318, 340, 360) blocks. DeSoto hemi (276, 291, 330, 341, 345) heads don't fit any poly blocks.
Boffin Emeritus
[Re: polyspheric]
#228111
02/18/09 12:57 PM
02/18/09 12:57 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
QFT.
Bore spacing is different. I checked on 'em all, because I was thinking of doing a swap onto a later lower end if possible (less weight and less $$$).
-bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
