Need Information #2278500
03/29/17 08:39 PM
03/29/17 08:39 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi. I need information on where to put the jack and the jack handle on my 1970 GTX. It's a tube jack. Not the t type. Any information is helpful!
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Need Information [Re: GTXKARL] #2278516
03/29/17 09:19 PM
03/29/17 09:19 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Is the spare bolted down just behind the seat back, on the right side? Is there 2 square 'loops' welded on that hump behind the seat back? One on the right under the spare, and another on the left side. If so the square tube jack-upright goes inside those 2 loops. The jack handle slides inside the tube before sliding the tube in place. The base plate gets bolted down on top of the spare tire with that tire hold down bolt and big wing nut. That is how my '71 Sebring was anyway.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Need Information [Re: GTXKARL] #2278710
03/30/17 02:24 AM
03/30/17 02:24 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
70 GTX/RR used 2 different jacks, T or tube depending on where your car was made, assuming this might matter to you?
go here for some pics, scroll down to 70 GTX/RR, click on pics to enlarge: http://www.nicksgarage.com/jacks.htm#bbody
Re: Need Information [Re: DAYCLONA] #2279175
03/30/17 10:44 PM
03/30/17 10:44 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi. I need information on how to store the jack. I have the jack, and as mentioned I have s tube type jack. I need t know where to put the handle. If you have any pictures or information I'd be grateful.
Re: Need Information [Re: GTXKARL] #2279185
03/30/17 11:05 PM
03/30/17 11:05 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
The "Jacking Instructions" sticker should show you. Assuming this is a hardtop (I'm not sure on convertibles), the jack & lever are secured by a bolt-on plate under the spare wheel/tire, with a threaded rod through the wheel center, with the jack base above the wheel, and the wingnut securing it all.
If you don't want the jack & handle scratching paint you'll probably need to put something between them and the trunk floor; same might apply to base & wheel.
