Re: 470 dry sump engine on the dyno
[Re: PETE@BESTMACHINE]
#2279516
03/31/17 12:50 PM
03/31/17 12:50 PM
Posts: 30,994 Oregon
AndyF
Would be nice to see actual dyno sheets to back up all these claims of horse power changes. Just saying Who prints dyno sheets anymore Pete? I'm all digital these days.
[Re: RustyM]
#2279519
03/31/17 12:52 PM
03/31/17 12:52 PM
AndyF
Please forgive a dumb question but, I won't know if I don't ask: How does the pan vacuum make more power? Better ring sealing? Oil staying away from crank journals?
Thanks Ring seal probably, maybe a little bit from reduced windage. This engine has an 043 top ring with lateral gas ports so pan vacuum probably helps the ring seal and maybe reduces flutter. Can't say I know for sure but more vacuum does make more power.
[Re: HotRodDave]
#2279524
03/31/17 12:59 PM
03/31/17 12:59 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I kind of like having a good port necked down a smidge at the opening so I can match it exactly to my heads, it makes the manifold a little more flexible as to what it will work with. I'm with Dave on this one. I'd rather the ports on the intake be a little small so I can match them to my heads.
[Re: als499]
#2279703
03/31/17 05:33 PM
03/31/17 05:33 PM
AndyF
Andy, are you running it with the 270cc heads today? Thanks! Yep, we changed over to the 270 heads on the dyno and made some pulls. Getting close to 760 hp even with the as cast Indy intake. This engine would probably make 775 or 780 hp if I had a really good intake manifold. The oil filter is super clean after every run so that is good news. The block must not be moving around too much even though we are getting up there in power. There doesn't appear to be any metal chips at all in the filters so we just keep making pulls.
[Re: AndyF]
#2279767
03/31/17 07:19 PM
03/31/17 07:19 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
From the old thread: High level summary is that it makes 700 hp with a Trick Flow intake and a QF carb. With the Wilson intake and a Dominator it makes about 720 hp. That was 10.5cr, wet sump, TF 240 heads.
[Re: AndyF]
#2279980
03/31/17 11:31 PM
03/31/17 11:31 PM
fast68plymouth
So. Burlington, Vt.
I have friends here very close to pulling the trigger on the 270 heads , however, as Dwayne mentioned in one of the threads- the 270 heads might not be the value the 240's are. Definitely not what I said, or implied. What I did say was that I didn't feel the 270's were going to have as much of an impact on the MW head market as the 240's have had on the std port market. They are still a very good value.
[Re: AndyF]
#2280163
04/01/17 09:10 AM
04/01/17 09:10 AM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
Ring seal probably, maybe a little bit from reduced windage. This engine has an 043 top ring with lateral gas ports so pan vacuum probably helps the ring seal and maybe reduces flutter. Can't say I know for sure but more vacuum does make more power. Pumping loss work should be lower with a vacuum in the crankcase, that is likely where the power is coming from. It is probably making about the same indicated power, but the brake horsepower is up from the lower pumping losses.
[Re: AndyF]
#2280390
04/01/17 03:23 PM
04/01/17 03:23 PM
fast68plymouth
So. Burlington, Vt.
I can't imagine what would be holding someone back from ordering either the TF 240 or 270 heads if they were building a combo where this is the type of head that will get the job done for them.
They aren't going to be substitute for a B1 head, or some of the bigger Indy heads, and probably aren't the best choice for a high cr big cube bracket motor where someone is looking to make 800hp+.
But if you were looking at "comparable" heads, and had these on your list of possibilities............ I can't see any reason not to pull the trigger.
Like the 240's, these heads are going to be very hard to beat from a power vs cost vs build quality standpoint.
There are other heads that will make just as much power(or more), especially if the motor is bigger and the combo is "racier", but it's going to cost more to get into them.
[Re: AndyF]
#2280426
04/01/17 04:45 PM
04/01/17 04:45 PM
fast68plymouth
So. Burlington, Vt.
The TF 270 heads with roller springs and Ti retainers are $2600/pr.
I've had 4 sets of the 240 heads in the shop so far, and the overall fit and finish was very consistent. They all had the guide clearance quite a bit tighter than what I prefer, and the seals are on super tight, so you can't get them off(or at least I don't seem to be able to) without ruining them. So, IMO, the "prep" for the TF heads is to disassemble, hone guides, clean everything, verify spring pressures and installed heights, reassemble with new seals. The roller springs that come on the TF heads(TFS-16318) are almost $340...... So you're getting pretty good parts there.
If you can buy the EZ295 for the same price as the TF 270, it comes with flat tappet cam single springs, steel retainers, 7 deg stamped locks, and umbrella seals. If you buy the upgrades from Indy to get the heads so they are "similarly equipped"(k-950 springs, Ti retainers, 10deg locks, viton seals)to the TF 270's, it's going to add about $500 to the cost. Then, if you really want them to perform like they should, the valve seats should be recut, valves back cut, and the bowls and chambers blended to the seats. Then, again you have cleaning, checking spring pressures, installed heights, assembly, etc......... All of which adds up to another $500. If you wanted spring cups, it adds another $100, and you'll also need the oil line kit for $55.
While i feel those two heads are pretty comparable, the place where the TF head really starts to look attractive is....... The price.
