Re: 470 dry sump engine on the dyno
[Re: AndyF]
#2278550
03/29/17 10:25 PM
03/29/17 10:25 PM
Posts: 30,947 Oregon
AndyF
This is the port match out of the box for the Indy 400-3. My guess is that you are leaving 5% of the power on the table if you run this intake as is. The port match isn't even close to be correct. If Indy would just spend 5 minutes and run a CNC pass around each port and matched it to their intake port it would save the little guy a bunch of time and effort.
[Re: AndyF]
#2278579
03/29/17 11:09 PM
03/29/17 11:09 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
2 sides to every argument...... The opposite view to "ootb intakes suck" is.... I've made 850hp with an ootb Indy 440-3.
[Re: fast68plymouth]
#2278611
03/29/17 11:46 PM
03/29/17 11:46 PM
Posts: 2,843 Pattison Texas
CSK
Pattison Texas
2 sides to every argument...... The opposite view to "ootb intakes suck" is.... I've made 850hp with an ootb Indy 440-3. Thats good to know,, WAY more power than my combination can make
[Re: AndyF]
#2278680
03/30/17 01:05 AM
03/30/17 01:05 AM
Posts: 12,408 Kalispell Mt.
HotRodDave
Kalispell Mt.
I kind of like having a good port necked down a smidge at the opening so I can match it exactly to my heads, it makes the manifold a little more flexible as to what it will work with.
[Re: RustyM]
#2278822
03/30/17 12:32 PM
03/30/17 12:32 PM
AndyF
How much of what we see in these mismatches can be attributed to core shift and how much to manufacturers not matching intakes to heads?
Thanks for all the helpful info guys- appreciate all you share. I consider it a missed opportunity by the mfgs to make extra money. If I sold CNC heads and I sold intake manifolds then the very least thing I would do is offer a CNC matching intake for an additional charge. The intake manifold already has to be in a machining center in order to surface the carb pad and drill and tap the bolts. Why not spend another 5 minutes of machine time and CNC the plenum for an extra $100 of revenue? Indy will CNC their dual plan intake to MW size if you ask so they know how to do this work. No idea why they don't take the next step and provide a good port match on the rest of their intakes.
[Re: AndyF]
#2279199
03/30/17 11:19 PM
03/30/17 11:19 PM
AndyF
Had some issues today but did manage to get some pulls done. One thing we figured out was that the billet valve covers are worth some horsepower so we switched over to them mid-day.
[Re: AndyF]
#2279231
03/30/17 11:54 PM
03/30/17 11:54 PM
Posts: 6,545 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Well it's too early for April Fools so what's the deal? Bulletproof valvetrain is distorting the head because of giant roller cam spring pressure so the billet valve covers act as a girdle? I don't see any oil lines to them for spring coolers. Kevin
[Re: AndyF]
#2279257
03/31/17 12:15 AM
03/31/17 12:15 AM
AndyF
[Re: AndyF]
#2279268
03/31/17 12:34 AM
03/31/17 12:34 AM
Twostick
Still wishing...
Still wishing...
How much were you losing? I would think the other covers would leak oil if it was that serious of a vacuum leak but I guess the vacuum would prevent that. At atmospheric they probably sealed up fine to keep oil in so negative pressure distorted the clear tops? Kevin
[Re: Coldart]
#2279513
03/31/17 12:50 PM
03/31/17 12:50 PM
AndyF
Who's oil pan? Looks nice, clean/sanitary package. Oil pan is one I had custom made. It is a billet pan.
