Window related parts?? #2276365
03/26/17 10:03 AM
03/26/17 10:03 AM
Akron, Ohio
VegasCharger Offline OP
Akron, Ohio
I found these in a sealed bag at the bottom of a box of window regulator associated parts. This was from a bulk buy and I didn't have time to go over every detailed parts he was including with the purchase.
Any help would be greatly appreciated. beer
Re: Window related parts?? [Re: VegasCharger] #2276539
03/26/17 03:23 PM
03/26/17 03:23 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Those are the window glides that go in the upper and lower front corner of the door glass, they ride in the fuzzy flocked channel of the A pillar vent window, 4 glides per window,2 inside, 2 outside, the pin connects the two pcs together thru a small hole in the upper forward and lower corner of the door side glass
Mike
Re: Window related parts?? [Re: VegasCharger] #2277025
03/27/17 10:21 AM
03/27/17 10:21 AM
Akron, Ohio
Akron, Ohio
Thanks Dayclona. I'll set them aside for safe keep just in case I'll need them in the future. Looks like I got enough for one window with 2 slides and 3 pins to spare.
Thanks again for your help. beer
Re: Window related parts?? [Re: VegasCharger] #2277079
03/27/17 12:09 PM
03/27/17 12:09 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
usually the 'fuzzy flocked channel' is shot too and the glides come with the channel if memory serves.
