2003 truck. Buddy needs help #2275592
03/24/17 09:29 PM
03/24/17 09:29 PM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
So a guy I know has 03 hemi truck 1500.4x4. Auto. He has no dash lights, radio, or hvac lights. He replaced gauge cluster, light bulbs, and headlight switch and still nothing. Any ideas?
"Think of all the Ford owners who will someday want an automobile." John Dodge
57 dodge sierra wagon
03 chrysler 300m
10 dodge charger
Re: 2003 truck. Buddy needs help [Re: Biggie] #2276277
03/26/17 01:02 AM
03/26/17 01:02 AM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
Nobody has had this issue?
03 chrysler 300m
10 dodge charger
Re: 2003 truck. Buddy needs help [Re: Biggie] #2276280
03/26/17 01:12 AM
03/26/17 01:12 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Only thing I would suggest is disconnect battery for 1/2 hour or so, re-connect and see.
Re: 2003 truck. Buddy needs help [Re: Biggie] #2276302
03/26/17 02:09 AM
03/26/17 02:09 AM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
Hopefully he doesn't have the dash light dimmer switch rolled all the way down which is off. whistling
My first guess would be to verify that power is coming through the roller dimmer switch on the right side of the main headlight switch.
If power is coming out of the switch, it is more than likely a wiring problem between the switch and the dash cluster lights.
Other than that, it maybe a grounding problem.
Re: 2003 truck. Buddy needs help [Re: Biggie] #2276825
03/26/17 11:18 PM
03/26/17 11:18 PM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
He has tried disconnecting battery with no luck. The first question I asked was if the dimmer was turned down. He said no. He will be checking it for power but was positive he has done that before. He will be looking for ground issues and any bare wires under there. Thanks for the input!
03 chrysler 300m
10 dodge charger
Re: 2003 truck. Buddy needs help [Re: Biggie] #2276972
03/27/17 04:44 AM
03/27/17 04:44 AM
A Red State
A Red State
He has verified that all the fuses are good too hopefully.
Re: 2003 truck. Buddy needs help [Re: Biggie] #2277419
03/27/17 11:07 PM
03/27/17 11:07 PM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
Yes. Said multiple times
03 chrysler 300m
10 dodge charger
