High output Toyota Alternator #2275099
03/23/17 11:58 PM
03/23/17 11:58 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I have seen these HO units that mod a 60 amp to 120-140-180 and keep the stk denso case. Has anybody had experience with these
Re: High output Toyota Alternator [Re: Scamp408] #2275144
03/24/17 01:18 AM
03/24/17 01:18 AM
Texas
mprhound Offline
mprhound  Offline
Texas
I had one of the 120 amp ones, lasted one drag week. Put on for 2015 dragweek did great, came home pulled the trans and motor didn't get it back in until right before drag week 2016, and it went out on the second day. So probably about 1300 miles on it.
Re: High output Toyota Alternator [Re: mprhound] #2275168
03/24/17 01:50 AM
03/24/17 01:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
And the biggest problem with it was all that
sitting.. I had a Jeep in the driveway and
it ran fine.. I got a new Jeep so it just sat for
a month or so.. I fired it up and the alt was
locked up.. I hit it with WD40 and in moments
it freed up.. just sitting kills them
wave
Re: High output Toyota Alternator [Re: MR_P_BODY] #2275283
03/24/17 10:59 AM
03/24/17 10:59 AM
moparx Offline
moparx  Offline
wave
you are so right about the sitting deal mr.p. ! i have a 120amp denso that is almost new from a minivan i am going to use on my humpback, and if i don't spin it once in a while, it gets real stiff ! before i install it for good, i'll just disassemble it and clean it up good. what causes these things to rust up so quickly ? the old round and square backs didn't have near the problems of becoming stuck sitting on the shelf. or am i just forgetting they did ? shruggy
beer
Re: High output Toyota Alternator [Re: Scamp408] #2275298
03/24/17 11:27 AM
03/24/17 11:27 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I bought a 100A reman'ed unit from an ebay vendor. The voltage regulator was not consistently regulating, so I pulled it off.
I heard the issue with the higher amp small units is heat...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: High output Toyota Alternator [Re: Scamp408] #2275829
03/25/17 09:09 AM
03/25/17 09:09 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
They don't sound to promising. Well I have a new 120 amp in the bigger case but I have to space everything out 1/2 inch to use including crank pulley
Re: High output Toyota Alternator [Re: Scamp408] #2275830
03/25/17 09:18 AM
03/25/17 09:18 AM
fullmetaljacket Offline
Using the 140 amp GM unit and no problems over the last 6 years. I was going to switch over to the Denso Toy version for weight esthetic reasons, but was told to stay put right where I am at.
The GM unit was about 2-3 Lbs lighter than my original Chrysler unit.
Re: High output Toyota Alternator [Re: Scamp408] #2275832
03/25/17 09:29 AM
03/25/17 09:29 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Doty Manufacturing makes some nice spacers for pulleys that he can cut to your needs. They are not cheap but very high quality.
68 Barracuda Formula S 340
Re: High output Toyota Alternator [Re: fullmetaljacket] #2276046
03/25/17 04:06 PM
03/25/17 04:06 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I am too clumsy...putting a saw blade on the front of the motor would likely result in lost digits
Re: High output Toyota Alternator [Re: Scamp408] #2276061
03/25/17 04:44 PM
03/25/17 04:44 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
East Coast Auto Electric will make you what you want.
Re: High output Toyota Alternator [Re: FastmOp] #2276817
03/26/17 11:07 PM
03/26/17 11:07 PM
Shelby Twp. Mi
HardcoreB Online content
HardcoreB  Online Content
Shelby Twp. Mi
I'd PM Jeff aka 590Challenger on here with the yellow Drag radial car...he should have any variety you need for alternators you'd want, at a good price too.
Re: High output Toyota Alternator [Re: HardcoreB] #2276990
03/27/17 08:06 AM
03/27/17 08:06 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
he's the one that told me about the bigger case 120 amp which I have on shelve. But to use it I need to space out everything 1/2in including crank pulley. Looks like my future involves and crank pulley spacer
Re: High output Toyota Alternator [Re: Scamp408] #2277066
03/27/17 11:50 AM
03/27/17 11:50 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I'v been using a 100a from a Toyota 4runner for maybe 10yrs now. no issues. this was bought at a starter alt rebuild shop.
Re: High output Toyota Alternator [Re: Scamp408] #2277143
03/27/17 01:50 PM
03/27/17 01:50 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
What year 4 runner? The tag from mine says 50 idle 80amp high rpm or close to that and it's not enough. I think it from a 87 toy p/u
Re: High output Toyota Alternator [Re: Scamp408] #2277319
03/27/17 07:51 PM
03/27/17 07:51 PM
Parts unknown
590 Challenger Offline
Parts unknown
87 Toyota 4runner is a 70 amp alternator, part number 100211-7570. 87 Toyota pickup is the exact same alternator
CS130 puts out 105 (stock) good power on the low end for street but not a good choice for racing, small bearing in the rear has always been a problem, you sure don't want it on your race car. CS130D (D is for double internal fan) is a much better choice for street, and race, it has a much better rear bearing (and probably front depending on alternator) and double internal fans for street. Makes it stay cool a lot better.
A good Denso is your best choice, and better yet their new style Hairpin alternators are just amazing
Re: High output Toyota Alternator [Re: Scamp408] #2277322
03/27/17 08:00 PM
03/27/17 08:00 PM
Parts unknown
Parts unknown
oh, and they do make special wound stators to make that Toyota alternator put out 90 amp or 120 amp where you don't have to change anything around from what you have. It might have heat issue if driven on the street drawing tons of power for too long. Great upgrade for the track thou
Re: High output Toyota Alternator [Re: Scamp408] #2277325
03/27/17 08:03 PM
03/27/17 08:03 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Thanks Jeff...Any PN's or applications you can think of that would be close to bolting up?
I remember looking up some JD applications, but worried about longevity at 6k rpm
Re: High output Toyota Alternator [Re: Scamp408] #2277328
03/27/17 08:14 PM
03/27/17 08:14 PM
Parts unknown
Parts unknown
First of all, Denso winds those rotors the same way if they are sticking them in a JD combine, Corvette or a Viper. I would not worry about it, you can always get a bigger alternator pulley to slow it down if you like.
Those stators are special winds, they do not come in anything. Normally if you want more amps than you have you must go bigger. If you need more power and all you do is race, stay with the Toyota one you have and change the stator. Less weight, less rotating mass too.
If you are driving it on the street drawing tons of power at an idle, you need a bigger alternator
Re: High output Toyota Alternator [Re: Scamp408] #2277345
03/27/17 08:49 PM
03/27/17 08:49 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I just needed some more amps as i had a problem with fan and the digital msd with the analogue one it was fine.I am fig another 20 amps.I may just bite the bullet and space it all out and run the JD one and be done.
Re: High output Toyota Alternator [Re: Scamp408] #2278075
03/28/17 11:49 PM
03/28/17 11:49 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
www.alternatorparts.com has a ton of big amperage units for lots of different applications...up to 350 amps !!!...nuts
