Re: Removable Parachute mount.
[Re: hemi-itis]
#2472557
03/26/18 11:53 PM
03/26/18 11:53 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
My Stroud launcher chute came in.Also bought an install kit and cable kit. Have to figure out the mounting situation for the launcher to be removable.The release lever is real chincey,should have grips like a pistol. I think I want to mount the lever on the floor.Does it matter where it's mounted as long as I can reach it?? Seems that most of the pictures I see the lever is overhead
[Re: hemi-itis]
#2472730
03/27/18 01:32 PM
03/27/18 01:32 PM
Posts: 235 Tucson AZ.
RADAMX
Tucson AZ.
mine is on the floor between the pass seat and the trans tunnel
I also have a removable chute mount . have to take a picture though
[Re: hemi-itis]
#2472740
03/27/18 01:47 PM
03/27/18 01:47 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
In a car without a funny car cage, we fab a U shaped mount, attached to the center of the main hoop, and extending forward to mount the lever horizontally, right where the driver wants it, with an attachment for the cable. The lever is mounted where the driver can pretty much swipe it with his hand without having to look for it and the whole affair is kept up tight to the ceiling so the guy's not bashing his head against it. We use Morse cables and proper mounting hardware. Not the cheap stuff that comes with the kits.
[Re: hemi-itis]
#2472827
03/27/18 04:01 PM
03/27/18 04:01 PM
hemi-itis
CMallister,thank you.I found some other ideas also.But the chute mount with the launcher will prove more difficult!
[Re: hemi-itis]
#2472850
03/27/18 05:03 PM
03/27/18 05:03 PM
Posts: 4,540 Motor City
6PKRTSE
Motor City
Mine on my Challenger before headliner was back in . .
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: hemi-itis]
#2472981
03/27/18 09:13 PM
03/27/18 09:13 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
FWIW on the Vette the handle is down on the console. It has T tops(well one piece of Lexan now)so it just looks better down low.
[Re: hemi-itis]
#2473019
03/27/18 10:42 PM
03/27/18 10:42 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
add another button to your shifter!
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: hemi-itis]
#2475633
04/01/18 10:14 PM
04/01/18 10:14 PM
hemi-itis
Found a mount picture to mount the pack.I prefer it close to the car like this ferd.The other one looks silly!
[Re: hemi-itis]
#2495097
05/12/18 02:10 PM
05/12/18 02:10 PM
hemi-itis
I looked at many pictures.It comes down to how you end up fabbing your mount.So this is how it ended up and it is detachable.
