Re: Fuel level sensor question
[Re: moparmandc]
#2276986
03/27/17 07:22 AM
03/27/17 07:22 AM
Posts: 5,754 ohio
ruderunner
ohio
Till the mid 90's or so, stock gauges were 10 full and 73 mt. Not sure what the 01 is but not likely 0-90, that's a GM scale and backwards from Mopar.
Angry white pureblood male
[Re: moparmandc]
#2277194
03/27/17 03:16 PM
03/27/17 03:16 PM
Posts: 25,729 Rio Linda, CA
John_Kunkel
Rio Linda, CA
From the '01 manual...
DIAGNOSIS AND TESTING - FUEL GAUGE SENDING UNIT
The fuel gauge sending unit contains a variable resistor (track). As the float moves up or down, electrical resistance will change. Refer to 8, Instrument Panel and Gauges for Fuel Gauge testing. To test the gauge sending unit only, it must be removed from vehicle. The unit is part of the fuel pump module. Refer to Fuel Pump Module Removal/Installation for procedures. Measure the resistance across the sending unit terminals. With float in up position, resistance should be 20 ohms +/-6 ohms. With float in down position, resistance should be 220 ohms +/-6 ohms.
